03' Ford Lighting Sputtering?
Old Jun 17, 2009 | 09:03 AM
NCLightning's Avatar
Exclamation 03' Ford Lighting Sputtering?
I recently bought a 03' L with 80K on it. I have dove it for about 4k and never had any issues with it at all. I haven't really gotten down on the gas from a stand still until this past weekend. I was going to powerbrake to warm up my tires to do a 1/4 mile pass and the motor bogged and wouldn't turn the tires or go above 2k. I got off it and then just stomped it from a dead still. After it shuttered a little bit it took off and went like a bat out of hell. I know a little about cars but not enough obviously cause i can't figure it out. It boost up to 8-10 fine once you get going. I replaced the fuel filter just because and looked for a vaccume leak but didnt' see anything. Any suggestions on what causes this. The truck has stock pullys, magnaflow exhaust and a Cold Air. Could it be a MAF? Any help is appreciated.
Old Jun 17, 2009 | 09:46 AM
sampson01's Avatar
Maybe check the intercooler pump I believe that's what its valled
Old Jun 17, 2009 | 09:38 PM
MbA0069's Avatar
Try the IAC (Idle Air Control). It was suggested to me, and I replaced it for about 50$ from autopartswarehouse.com, fixed the problem.
Old Jun 18, 2009 | 04:46 AM
Veteran: Army
when you powerbrake don't hold the brake pedal all the way to the floor just enough to keep the truck from moving forward
what octane are you running? when is the last time you changed the cops, plugs, and air filter?????
Last edited by stoffer; Jun 18, 2009 at 04:47 AM. Reason: removed the fuel filter since he just changed it
Old Jun 18, 2009 | 08:45 AM
I always run 93. I haven't changed the COP ever but plugs were changed about 15k ago at a stealership. The air filter was cleaned about 3k ago. I don't hold the brake pedal down all the way in fact i start a roll and gas and brake just enough for it to stop rolling but no spinnage. Even from a dead stop taking the foot completly off the brake and stomping the hell out of the gas it will not spin but rather lurge forward while shaking a little at after about the 15mph mark it will go ahead and fly. Do the COP need to be changed that often? I thought they were lifetime things? What do they cost?
Old Jun 26, 2009 | 01:38 PM
phenom1011's Avatar
It will sputter if the COPs are bad.
Old Jun 30, 2009 | 11:30 AM
wheres the best place to pick up new COP's? Aftermarket better or just oem? Thanks guys
Old Jul 1, 2009 | 07:59 PM
I have a game plan for the long weekend. New TR6 plugs and see if that straightens things out if not going to get either accel or msd CoPs. I drove it again a day or so ago after coming back from my honeymoon and under everything i could stomp the pedal to it only boosted to like 6-7 I live in North Carolina at the beach and it was about 90 out but what boost should I have here? Any help is greatly appreciated guys!
Old Jul 4, 2009 | 04:57 AM
phenom1011's Avatar
I have a stock 03 and I'm at about 9 in 80 degree weather. I have the boost by pass mod and a drop in K&N filter. Stock is suppose to be around 8
Old Jul 6, 2009 | 11:47 AM
Well when i changed the plugs this weekend I found a couple vacuum leaks on the backside of the motor. One was the boost gauge. Fixed all those, changed to TR6's and she'll roll like a scalded dawg now. Everything is fixed and runing great it appears. The 4# pulley and tune will come soon now.
Old Jul 9, 2009 | 11:26 AM
Darnell@Hypertech's Avatar
Former Sponsor
Did you check to see how the old plugs were gaped? Both times I've had a trouble with a sputter it ended up being the plugs, but I'm sure my time for COP change is coming soon enough
Old Jul 9, 2009 | 06:41 PM
yeah i did they were not consistant at all, a couple were about to fall off it looked like
Old Jul 11, 2009 | 11:26 PM
AA_Expert's Avatar
What he said. Same thing happened to me.
