Hp and Tq difference between 99-01 lightning?
Old Jun 9, 2009 | 02:27 AM
20Screw01's Avatar
I bought a 2000 lightning engine for a swap into my f150 and I was wondering what makes the 20hp and 10 tq difference from the 99-00 to the 01-04 lightnings?
Thanks Dave
Old Jun 9, 2009 | 02:45 AM
silversvt04's Avatar
There is a smaller maf in the older lightnings, and I also believe that the inter cooler is smaller.
Old Jun 9, 2009 | 04:14 AM
STRK BY's Avatar
It's the factory tune..they recalibrated it every year...with 04 being the best @385/450ft lb..and a 90 mm maf and larger itake tube.......
Old Jun 9, 2009 | 07:13 AM
Veteran: Army
the '99-'00 made 360hp, they also had a different lower intake and mid plate hence the different bolt pattern on the eaton but they can be machined to interchange
make sure you get a 90mm MAF before you install the motor
Old Jun 9, 2009 | 10:29 AM
20Screw01's Avatar
I have a ba2400 90mm that I will be putting on. What kind of power should I get out of a stock 2000 L motor with that maf and a tune with decent exhaust? What can I do to upgrade to the 01 style intercooler and intake tube? I need to end up with 450-500 tq...
Thanks Dave
Old Jun 9, 2009 | 10:42 AM
Veteran: Army
Thanks Dave
I'd run a 4# lower and see what happens, you should be real close
I hope you've helped your tranny out if not that'll probably be the first thing to go
*edit* the intercooler core in interchangable you need to count the rows it has, maybe you have the upgraded factory one now
Last edited by stoffer; Jun 9, 2009 at 10:43 AM. Reason: forgot the intercooler core info
Old Jun 9, 2009 | 10:52 AM
20Screw01's Avatar
Any idea where to buy a 4# lower pulley and a intercooler pump cheap and how much total boost will I get? Also how many rows does the standard intercooler have compared to the upgraded one? I need a way to tell what year this motor is because im not completely sure?
Thanks Dave...
Old Jun 9, 2009 | 11:09 AM
Veteran: Army
lightning force performance, JLP, woodbine, avoid RPM outlet and remember you'll a pulley for the '99-'00 if indeed that's the year of motor you have 'cause they changed the factory crank balancer for the '01 models as well
Old Jun 9, 2009 | 11:38 AM
20Screw01's Avatar
Is there anyway to tell for sure what year the motor is? And if the factory upgrade has been done?
Old Jun 9, 2009 | 12:40 PM
Veteran: Army
the '99-'00 trucks had a 9 row stock and I believe the factory upgrade had either 10 or 11 rows
take a picture of your intake runner (the part between the midplate and head) and we can tell you what year of motor you have
Old Jun 9, 2009 | 01:43 PM
20Screw01's Avatar
Sounds good I get the motor this week so I will take a peak and post it here. Anything else I should look for while its apart?
Old Jun 9, 2009 | 03:34 PM
Veteran: Army
clean your intercooler, TB, upper plenium and install an oil seperator before you drive it...
Old Jun 9, 2009 | 03:47 PM
20Screw01's Avatar
Which line/breather do you install it on?
Old Jun 9, 2009 | 04:44 PM
Veteran: Army
c'mon what's with all the questions???
just kidding, it goes in the one from the passenger side cam/valve cover to the eaton, there are a few nice ones out there, the DMR looks the best but the L&S is maintainence free
Old Jun 9, 2009 | 06:49 PM
20Screw01's Avatar
Perfect thanks man!
