lowering front of a 2001 lightning.
Old May 8, 2009 | 11:02 AM
eric2561's Avatar
I am lowering the front with Eibach springs, do I have to change the shocks?
Old May 8, 2009 | 11:13 AM
polpilot's Avatar
Do you have to? the springs will be shorter, so withe that id say yes... but the way i look at it, its all going to be apart, so i would do it anyways. and if there factory, they proubly need it anyways.
Old May 8, 2009 | 02:00 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
..only if you want your existing shocks to last.
Old May 25, 2009 | 01:39 PM
lokilightning's Avatar
You do NOT have to change your shocks with that little of a drop. You will not get the full range of movement out of the shock, but it is not enough to blow the shocks. It is usually advised to change them because the ride gets a little stiffer, but is not required.
