Royal Purple question
Old Mar 22, 2009 | 04:38 PM
SVT_OFFICER's Avatar
Hey guys my stock L. is going to hit 50,000 miles anytime soon. Im thinking of changing the rear end oil and trans oil too. Is it around the time those two should be changed. Also heard real good stuff about royal purple so does anyone recommend which type to put on both trans and rear end? thanks
Old Mar 22, 2009 | 05:30 PM
spoiled's Avatar
I have a modded Mustang and a manual tranny. when i changed the tranny fluid with RP it was night and day difference. I also use it in the engine and it does well.
Old Mar 23, 2009 | 01:08 PM
yeah i know what you mean i used to use mobil synt. and went with rp and smoother acceleration. But should i change both trans and diff at this milage?
Old Mar 24, 2009 | 02:40 PM
Robert Francis's Avatar
What does your Ford manual recommend?
Old Mar 28, 2009 | 01:33 PM
my truck didnt come with manual. the only online manual i could find was th dvd that lfp makes but thats like $30.00
Old Mar 28, 2009 | 09:48 PM
TrackBeast's Avatar
I don't sell or promote anything but I found this independant gear lube study to be very informative. You can download the PDF. Interpret it as you wish.
http://www.amsoil.com/products/gearl...hitePaper.aspx
Old Mar 29, 2009 | 08:34 PM
interesting.... i would like to hear as many inputs from all users. Thank guys
Old Apr 6, 2009 | 12:33 AM
batrup99jeremy's Avatar
my harley truck just rolled over 54k miles and i'm very interested in changing my trans and rear end fluid. what do you guy recomend? also does anybody know how much fluid the trans and rear end hold?
Old Apr 12, 2009 | 10:02 AM
99 SVT Bolt's Avatar
bobistheoilguy.com
Old Apr 29, 2009 | 06:41 AM
Crewie's Avatar
I just changed all of my fluids over to RP.
The tranny is a 17 quart system-changing over to RP is like night and day.
The dif I believe is 2 quarts or so. I used RP 75-90 when I had my changed. Also make sure you use the proper additive for the posi rear end.
If you want to add Purple Ice to your raditior it is a 25.5 quart system and taked about a bottle and a half. The intercooler is a 4.5 quart system and you can use the Puple Ice in the intercooler. It has the same antifreeze as the cooling system. I know this only because I spent 2 hours on the phone one day calling: Ford Performance, Royal Purple, and JDM. After talking to all of them I felt comfortable putting the Puple Ice in my intercooler tank.
If any of you follow these threads-Thanks to Ford, RP, and JDM, they all had great ideas and even better answers.
Old Apr 29, 2009 | 05:46 PM
TrackBeast's Avatar
What do you mean by night and day?
The diff. is 75W-140. The 90W may puke through the breather as its way too light.
