Adj. Rear Swaybar End Links?
Old Feb 27, 2009 | 10:28 AM
Thor'sLightning's Avatar
Im lowering the back of my truck 2 inches with hangars and I was thinking that I should go with getting the adjustable rear sway bar end links. I found them on Jegs and Summit but on there it says they are for 99-02 and I have an 04. I was wondering if they will still work on my truck? Is there any difference between sway bars from the 99 - 04 or what? Any help on this would be appreciated.
Links:
http://store.summitracing.com/partde...5&autoview=sku
http://www.jegs.com/i/Competition+En.../7990/10002/-1
Old Feb 27, 2009 | 04:12 PM
pitstain's Avatar
They will work on all years of Lightning, but the free option is to simply drill new holes on the frame a couple of inches higher.
Old Feb 27, 2009 | 07:22 PM
Dbl G's Avatar
Easy and a simple way to go.
Old Mar 13, 2009 | 07:58 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
The Competition Engineering center sleeve is too long for a 99-02. You'll probably send up drilling a new hole anyway.
The set I used many years ago with good results was from So Cal Speedshop. And they are cheaper.
http://www.est1946.com/endlinkkit.aspx
FYI, A set of heim joint covers would do you good as they will get all sorts of debris in them.
If I had to do it all over again, I'd either drill a new hole (easiest) or have the factory end links shortened.
Bob
