just bought an 04 lightning and had some questions
Old Jan 24, 2009 | 04:59 PM
jran77's Avatar
my motor acts like its not getting enough fuel, it still has all factory fuel system what is the best system to get
Old Jan 24, 2009 | 09:15 PM
Robert Francis's Avatar
Depends upon what modifications have been made to the engine. If it's stock, the standard fuel system is more than sufficient.
Old Jan 25, 2009 | 06:20 AM
Veteran: Army
maybe it has a clogged fuel filter?
when you bought it did you change all the fluids and filters? or did you just jump in and go and now it's acting up you're worried
what is the truck doing? how did you reach the assumption it's not getting enough fuel
Old Jan 25, 2009 | 01:44 PM
jran77's Avatar
well im not much of a mechanic so i dont know a whole lot about it but when i give it full throttle it cuts out and falls on its face but if i ease into it its fine... the trucks not stock either it has custom exhaust, suspension, cold air, smaller lower pully, and the diablo computer
Old Jan 25, 2009 | 01:51 PM
Cub Cadet's Avatar
This is a comon problem and is one of two things. Change your fuel filter first and see if the problem goes away. If not, then your problem is at the in-tank fuel pumps... one of the hoses has fallen off. If you are in there fixing this issue get new, aftermarket fuel pumps.
Old Jan 25, 2009 | 02:22 PM
Lumadar's Avatar
A canned tune coupled with several mods affecting the AF ratio isn't a great idea either. I would suggest finding a REPUTABLE tuner to have the truck custom tuned and dyno'd.
Old Jan 25, 2009 | 03:45 PM
Ace85's Avatar
Check the spark plugs and wires also.. same symptoms were happening in my friends car. We changed out the plugs and wires acceleration was like driving a new vehicle.
Old Jan 25, 2009 | 07:11 PM
jran77's Avatar
thx
Old Jan 26, 2009 | 12:09 AM
silversvt04's Avatar
I had the same sounding problem and it was a coil pack. under wot the truck would start to rev and pull strong then stumble, still pulling but not as it should have.
No detonation?
Old Jan 27, 2009 | 05:45 PM
Struck in AZ's Avatar
Wires? No such monster on the L since it's got the COPs.
