Looking for lowering shackles?
Old Sep 24, 2008 | 09:01 PM
SVT_OFFICER's Avatar
Any advice where and which ones? Or should i just get the ford racing one'S?
Old Sep 24, 2008 | 09:07 PM
just about any shackle will work just fine. Ground force and DJM are pretty good and common. see if you can find a used set somewhere online in the classifieds, here and other websites.
Dont forget to get 2* pinion angle shims
Old Sep 24, 2008 | 09:12 PM
what and where can i find those pinion angles? I have'nt heard of them for my 02 L?
Old Sep 24, 2008 | 09:16 PM
DJM sells them seperately with their shackles
ground force includes them in their new kits.
its a metal wedge that goes between the leaf and the axle.
(stock left 6* shim on right)
Old Sep 24, 2008 | 09:19 PM
cool man thanks. You guys are well prepared in this site!
Old Sep 24, 2008 | 10:39 PM
Tim Skelton's Avatar
You really need to measure the angle! Do not assume that you either need them or don't.
Old Sep 26, 2008 | 01:57 AM
thanks Tim i will for sure
Old Sep 26, 2008 | 05:00 AM
Veteran: Army
I'm running the belltechs and did not need the pinion shims
Old Sep 26, 2008 | 12:56 PM
LUKE_DUKE's Avatar
Same here with the Belltechs.. bought mine used for $50..
Old Sep 27, 2008 | 02:29 AM
MHMCGILL's Avatar
FWIW when I did my '03 I just flipped the shims around and that cured the vibration.
Old Sep 27, 2008 | 09:15 PM
stock shim is a 1/2* shim. you can actually see very slight taper to it in my pictures above
