Input please
Old Sep 3, 2008 | 06:41 PM
Dork-N-Beans's Avatar
Input please
My plan is a built short block,stock heads,crower stage1 cams(or other cam )stage4 ported eaton,60# injectors ,mafia, 6 or 8 lower,dyno tune.what did I leave out? with this combo whats a better cam? Thanx guys
Old Sep 4, 2008 | 07:02 AM
torkum's Avatar
Don't forget long tube headers.
Old Sep 4, 2008 | 07:29 AM
Veteran: Army
I'd run the 8# lower with a stocksize non-slip head pulley from riechard racing, Long tube headers as previously mentioned; also I'd recomend at least port and polishing the heads and lower manifold, upper plenium, swap to '97 f-150 fuel rails and better fuel pumps.
if you haven't allready done so now would be the perfect time for a valvebody in the trans and a better converter.
as far as the cam goes, the low lift stage 2 supercharger specific cam from crower looks like a pretty good street cam but I would call them and discuss your goals and uses with them and let crower recomend a cam for you.
congrats on the build
Old Sep 4, 2008 | 01:49 PM
Thanx guys
Old Sep 4, 2008 | 05:51 PM
phil6608's Avatar
Do ported heads wile it's out of the truck. If not,,,you'll be sorry later that you didn't.
Unless you already have the ported blower,,I would sell it and get a used 2.3 KB or Whipple.
Phil
Old Sep 4, 2008 | 09:49 PM
torkum's Avatar
Whats the difference on the 97 fuel rail and is the 98 the same?
Old Sep 4, 2008 | 11:59 PM
Veteran: Army
something about the fuel regulator, I believe that it is external or adjustbale give me couple days and I'll get back to you, too busy at work to go back over all my notes
I don't know if the '98 is the same
