80mm vs 90mm???
I want to know which one ir really better. I have a 00 Lightning, with my truck and mods am i better off with the stock 80 or keep the 90, since i really didnt see any gain with it? Any comments would be great. Thanks
2000 WHT LIGHTNING
#2013 Born 4/6/00
Stock 14.03 96.3mph
w/superchip 13.53 101.5mph
w/superchip and JL filter kit 13.23 @ 104.5
New for this year:
Bedrug, Ford Tonneau Cover
Ford SVO T/B, 90mm Mass Air
Ford Oil Breather
JDM 2nd Chip reburn
PSP Lower Pully
Hopefully a 12.XX
This Fall 75shot NOS
18" Nitto Drag Radials
2000 WHT LIGHTNING
#2013 Born 4/6/00
Stock 14.03 96.3mph
New for this year:
Ford Oil Breather
JDM 2nd Chip reburn
PSP Lower Pully
Hopefully a 12.XX
Sorry that I really don't have an answer to your question, but I have the 90mm also on my 00 and it seems to me that the more air you can feed your motor- the better...but I can't back that up. Its funny that you asked this question, though, because I was going to ask a similar one too; so let me just make a friendy amendment...
did any of you guys that had run the Pro-M 80mm mass air before (I'm looking mostly towards the 99 and early 00 owners) switch over to the 01 Ford OEM mass air and notice any gain/loss in performance. Following what I had said earlier, it seems that the more the better, but I wasn't sure if the Pro-M possibly had a better design or something to that effect. Thanks, later...
Being Single...
Seeing Double...
Going for the triple
(((Garrett))))
'00 Silver Lightning
'01 CR250
'00 NESC MX Amateur Champ
#65 NESC / #465 AMA
motoxer@wpi.edu
gkaye@rjagroup.com
AOL IM: GK65A
Being Single...
Seeing Double...
(((Garrett))))
'01 CR250
#65 NESC / #465 AMA
motoxer@wpi.edu
gkaye@rjagroup.com
AOL IM: GK65A
I posted this same question over on PSP board. I have a PRO-M and was thinking about upgrading to a 90. Heres what Sal said,
"Noel, the 90mm only flows 4.7% more air than the Pro-m, so if you have the Pro-M, there really no need to upgrade."
noelvm
"ANYTHING OTHER THAN 1ST, SUCKS" (D.Earnhardt)
99.5 Red Ligntning, Mobil 1, PRO-M 80 MM MAF/filter, Custom Superchip, Eldebrock 5512 muffler, Sals lower Pulley, CAL TRACS, MT ET Streets, best time (1/8) 8.19, Bugflector II, G&H Lens covers head & fog, 200 WT Pioneer 4 CH AMP, BOSE 301 SERIES IV SPEAKERS (IN BACK)LONESTAR RACEWAY 2000 ROOKIE OF THE YEAR, STREET STOCK CHAMPION 01-01 TO 06-01 LONESTAR RACEWAY
noelvm
I had the Pro-M 80mm on my '99 and switched to the 90mm. The Pro-M also bumps up the timing a little, so its not an apples-to-apples comparison. I also have the oval tb. The Pro-M was a little more responsive off idle, no doubt, but my truck is a consistent 2 tenths faster with the 90mm. However, the 90mm required a new chip, so that's not really a straight comparison either. The big point to me is that it behaves better with the 90mm. With the Pro-M I occasionally got a lean error, occasionally had a flutter at idle, and occasionally had suging at low speeds. Now it runs like a stocker but faster.
Spiro,
Can you shead any light on this? I am a bit curious myself what the differences are between the 80 and 90 performance wise.
Sam
Sam
WHTLIGHTN,
Let me know if you need a 90 mm sensor. I have an extra one for sale.
Thanks.
hockeybuff@earthlink.net
2000 Lightning Red #1554/4966 born 3/24/00
JDM street chip
Factory 90 mm mass air kit
13.48 @102.34 mph
best 60' 1.994
Thanks.
JDM street chip
13.48 @102.34 mph
best 60' 1.994
