Anyone with pictures of the sender for water temp gauge?
Old Jun 18, 2001 | 08:15 PM
EvilGuy's Avatar
Post Anyone with pictures of the sender for water temp gauge?
I didn't realize that I would have to tap the intake manifold to attach the temp sensor for an aftermarket gauge. Does anyone have pictures of this?
Old Jun 18, 2001 | 08:49 PM
ASVTFordBoy's Avatar
Question
Do a search. There are some pics of the sending unit tapped into the thermostat housing. The only problem with this is it doesn't read engine tempurature until the thermostat opens. Since my primary use of the temp guage will be for the track, I have been looking for some other place to put the sending unit. Anybody have any suggestions?
2001 Black Lightning
picked up 3/20/01
14% tint sides and rear
Line-X Bedliner
K&N, 26 X 10.5 M/T ET Streets and more to come
Best E.T.: 13.462 @102.30 (actual time slip)
Best 60': 1.93
Old Jun 18, 2001 | 08:59 PM
Don C's Avatar
Post
here you go temp sensor tapped into the intake manifold. There is a coolant passage under there
http://donf150.tripod.com/Welcome/id6.html
http://communities.msn.com/MyFordF150&naventryid=100
13.11 @ 104MPH
Old Jun 18, 2001 | 09:07 PM
EvilGuy's Avatar
Post
Don not to sound like a moron, but is it the one in the clearing, near the middle of the picture? with the brass nut and the red tape around it?
[This message has been edited by EvilGuy (edited 06-18-2001).]
Old Jun 18, 2001 | 09:22 PM
Don C's Avatar
Post
Evil Guy thats the one. If you have any questions call Jim at JDM thats off his page at svtperformance.com Thats the sensor for Jims electric fan maybee for a guage it might be different.
[This message has been edited by Don C (edited 06-18-2001).]
Old Jun 18, 2001 | 09:48 PM
BadAzz516's Avatar
Rest In Peace
Lightbulb
Hey guys I found a great spot for the sending unit for the water temp guage its the drain plug for the block its right behind the oil filter and all you need are some brass fittings and the sending unit will screw right in there no drilling and you get an accurate reading just replace any antifreeze you lose and you are set
Old Jun 18, 2001 | 10:01 PM
bobcmt's Avatar
Post
Like the idea of putting behind filter. I drilled my intake and was able to cut threads, but it was a very nervous few minutes. The intake casting was extremely thin, had to be extremely careful not to pull threads when tapping and again when tightening sensor. Thought I might have to have a bung heli arc'd onto intake. Manifold can not be more than about an 1/8 th inch thick. - Big Bob
Old Jun 18, 2001 | 10:18 PM
Smile
Great info BadAzz. I didn't really want to drill, tap, etc. and risk messing up my intake. What is the best place to run the wire into the engine compartment from the guage?
[This message has been edited by ASVTFordBoy (edited 06-18-2001).]
Old Jun 18, 2001 | 10:21 PM
noelvm's Avatar
Lightbulb
Badazz found the correct place. This is the one my mech found when he was putting mechanical gauges in a Cobra R. It's deffinately the right spot.
noelvm
"ANYTHING OTHER THAN 1ST, SUCKS" (D.Earnhardt)
99.5 Red Ligntning, Mobil 1, PRO-M 80 MM MAF/filter, Custom Superchip, Eldebrock 5512 muffler, Sals lower Pulley, CAL TRACS, MT ET Streets, best time (1/8) 8.19, Bugflector II, G&H Lens covers head & fog, 200 WT Pioneer 4 CH AMP, BOSE 301 SERIES IV SPEAKERS (IN BACK)LONESTAR RACEWAY 2000 ROOKIE OF THE YEAR, STREET STOCK CHAMPION 01-01 TO 06-01 LONESTAR RACEWAY
Old Jun 18, 2001 | 10:29 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Arrow
Evil,
I tapped mine into the thermostat housing like so.
The sending unit doesn't touch the thermostat however there is a drawback. The gauge only works when the thermostat is open. Personally, I'm not real concerned when it is closed anyway.
Brake Late, Dive Deep
Speedin Bob, Owner/Operator/Pilot
Lightning #2504, 6/17/99
NLOC # 438
**THIRD intercooler**
...NEXT!
Zing Site Speedin Bob's pics
Old Jun 29, 2001 | 08:24 AM
cobra99's Avatar
Post
Speeding bob how has it worked so far?
also has anyone tried something different ?
Old Jun 29, 2001 | 08:30 AM
cobra99's Avatar
Post
Does anyone have any pictures of the spot behind the oil filter AND THE PARTS THEY USED? thanks
Old Jun 29, 2001 | 09:15 AM
Arrow
Cobra,
it works great (tells me when the stat opens too)
without looking, I'm not sure how much room there is to drill but the tap should fit.
Old Jun 29, 2001 | 09:53 AM
Totaled's Avatar
Exclamation
<font face="Verdana, Arial" size="2">Originally posted by EvilGuy:
</font>
EvilGuy,
Do you have an 01? The picture posted above is from my 01 which has a different intake than the 99 and 00's.
01 Silver Lightning
Delivered 3-20-01
12.61 @ 107.56
