Possible connection problem with flip chip?
Old Jun 27, 2001 | 07:47 PM
2_FAST4U's Avatar
Question Possible connection problem with flip chip?
I tried to install my flip chip yesterday and I pulled out the CM and took it apart. I cleaned the connections good and installed the chip and put the computer back in (negative battery cable disconnected). I went to start my L and all the gauges went to the right and the engine would just turn over (no detonation). I removed the CM three or four times and cleaned the connections for the CM and the chip and it does the same thing. I am just wondering if anyone else has seen this problem and if it is a connection problem. I am going to have someone look at it tomorrow who has done these chip installs several times and we will see if it is my connection cleaning skills or the chip. The connections for the computer module are so clean that you can see yourself in them, and the only other conclusion I can come to is that there are tiny pieces of silicon in the chip connections. Any thoughts would most gratefull.
14.026@97.12--Bone Stock
2000 Black Lightning
01' tail lights
Borla cat-back system
Lebra Tonneau
JDM 90mm MAF
JDM Oil Breather
JDM Flip Chip
kylerobeson@hotmail.com
my web site
Old Jun 27, 2001 | 08:05 PM
Totaled's Avatar
Post
Kyle,
Try taking out the computer again and remove the covers. Hold the board at different angles so you can see every possible angle for that silcon stuff left on the contacts. A few weeks ago at VMP Greg(he was there Saturday only)experienced a problem: every time he would install his chip the truck would go slower than stock by around a tenth. We took his computer out, disassembled it and that silcon stuff was still on the contacts which you could only see a different angles not straight on. We cleaned the contacts good and he gained .6 BTW - he told me before we took it out that he was afraid he had ruined his computer by cleaning it too good by rubbing through the contacts.
Good luck!!
01 Silver Lightning
Delivered 3-20-01
12.61 @ 107.56
Old Jun 27, 2001 | 08:17 PM
2_FAST4U's Avatar
Post
Totaled,
Thanks for the advice, Me and Brian K are going to fool with it tomorrow and I will do what you said. BTW-Thanks for the vid and I remember that pic, I think you were racing me!!!!
STATISTICS SHOW THAT BLACK WILL BE FASTER...LOL
01' tail lights
Lebra Tonneau
JDM 90mm MAF
JDM Oil Breather
JDM Flip Chip
my web site
Old Jun 27, 2001 | 10:46 PM
WHAT04's Avatar
Post
Try just installing the PCM without the clip holding it in place. The ridge on the PCM holding plate (cage) may be pushing the chip away from its contacts.
In my opinion, the PCM cage should be removed and have the edge flattened where the chip rests against it. It's a b!tch to do, but you'll never have an install issue again.
2001 Red Lightning Delivered 3-15-2001, 2" Aim Lowering Shackles, Hitch Removed, Group Purchase Floor Mats, Modified Light Switch for Fogs, JDM Filter Kit, Single-Bladed T/B, Keyless Entry, Magnaflow 14568, (BABolt) Polished Stainless Exhaust Tips, Lo Tek Pillar Pod, 22% Tint, Chrome '00 Rims, Bed Rug, M Pulse Lo-Pro Tonneau, Other Goodies. Best Time: 13.41 @ 104.37 mph
2000 Red Lightning - #835 of 4966 Sold 3-8-2001
2001 Yukon Denali White, All Stock
My Zing.com Album Click Here
Old Jun 27, 2001 | 10:53 PM
ovalbuddy's Avatar
Lightbulb
I've had the exact thing happen to me twice. When I turned the key on, all the gauges went far right--talk about a SCARE! I immediately turned the key off and disconnected the battery (-) once again. After about 10 minutes, I reconnected the battery, started the truck and everything has worked fine since then. I did'nt deinstall/reinstall the computer between battery connections. You might give it a try .
Old Jun 28, 2001 | 10:35 AM
jarmstro's Avatar
Post
All,
Your gauges will all peg when you clear the PCM and first turn key on.
Next time turn key on let gauges settle back where they are suppose to be, push lump in throat back down into your chest and then start truck
John Armstrong
2000 Red Lightning
#444 of 4966
Born 2/22/2000
Went home 3/6/2000
Old Jun 28, 2001 | 06:52 PM
wrightlightning's Avatar
Post
Check for the silicon inside your module. I had a similar problem with mine.
Black '00
#2216
Old Jun 28, 2001 | 08:32 PM
2_FAST4U's Avatar
Post
I got it now, working fine!!!!!
01' tail lights
Lebra Tonneau
JDM 90mm MAF
JDM Oil Breather
JDM Flip Chip
my web site
Statistics show black is the fastest!!
Old Jun 29, 2001 | 12:03 AM
Silver_2000's Avatar
Talking
You may have seen it already but I took some pictures of the process when I cleaned the Computer
http://www.svtlightnings.com/svt/chip/chip.htm
It is a lot easier if you pull the box apart.
I bet there is still coating on the contacts
Doug
Old Jun 29, 2001 | 07:19 AM
WHAT04's Avatar
Post
So what was the fix????
