Clay bar before Cherry Wet Wax?
Old Jun 27, 2001 | 10:07 PM
dogman's Avatar
Question Clay bar before Cherry Wet Wax?
I have been waxing with Zymol. Wasn't worth the effort at all. Just received my Cherry Wax from Coats. Should I clay bar before applying Cherry Wax? Will the shine be that much better if I clay bar versus just applying the new wax? What is this I have seen about guys using Dove to take off old wax. I thought you did not want to use detergents of any sort. Appreciate any first hand experience you detailers and car show winners have.
Silver 2000 Lightning
Built 5/26/00
#3299 of 4966
Bone Stock
SnugTop Tonneau Cover
Old Jun 27, 2001 | 10:20 PM
Edward's Avatar
Lightbulb
I clay my vehicles about twice a year or more. My primary reason for claying is to remove contaminants from the paint without an abrasive cleaner/compound. Claying will also remove bugs, pollen, and sap that may be embedded in the paint. However, it will not remove stains or damage left by the contaminants. Using a dishwashing detergent will remove the wax from your paint. The purpose for this is to start off with a "clean" surface. You shouldn't use Dove/Dawn/Joy after you have applied your Cherry Wax because it will get stripped off. If, however, if you are using a polymer-based polish such as Zaino, the dishwashing liquid will not harm the finish.
Old Jun 27, 2001 | 10:29 PM
Flintstone's Avatar
Post
Dogman
use the clay bar first to get bugs & tar off
run your hand over paint feel not smooth
like glass than use clay bar over the area.
i used meguiars clay bar comes to use with
quik detailer. spray spot with quik detailer
and clay bar then go over spot it will
remove the blemish price 9.99 for bar & detailer. then i used the cherry wax
finish smooth as glass
jdm street chip
90mm maf & breather cap
transgo shift kit
13.30 107mph
Old Jun 27, 2001 | 11:59 PM
Edward's Avatar
Red face
I would not recommend the Meguiar's clay. I have used it in the past; but I feel that it leaves too many clay streaks regardless of how much detailer I used. I would suggest either Clay Magic or Zaino's Z-18 clay bar. Neither of the these two will leave streaks nearly as bad as the Meguiar's.
Old Jun 28, 2001 | 08:42 AM
dogman's Avatar
Smile
Thanks for the help.
dog
Old Jun 28, 2001 | 08:52 AM
lrutt's Avatar
Post
Got my clay from the same place I got the Cherry wet wax. They had 2 'grits' of clay. You get the fine for dark colors, the heavier for lighter colors. Well worth the effort, just make sure you use plety of lube when claying. Check my sig for a clay'd and Cherry'd Screw.
- 2001 F150 Harley Davidson Special
- 1993 Mazda Miata, wifes car
- 1994 Harley Davidson Heritage
- 1976 Honda CB750K, Original
- 1965 Honda 305 Dream, Original
- 1971 Triumph Trophy 650, Original
- 1971 Norton Commando
- 1970 Honda Trail 90, Original
- Yamaha 500 Short Tracker, racing #69
- 1984 Yamaha Virago 1000, wifes bike
- 1981 Honda Passport 70, wifes bike
- My on-line album
- My Webpage
Old Jun 28, 2001 | 09:55 AM
NeedFourSpeed's Avatar
Post
Clay it then hit it with some 3-M imperial hand glaze.
Old Jun 28, 2001 | 10:07 AM
93Cobra's Avatar
Post
dogman-
Why did you stop using Zymol? I swear by that after everything that I have tried. I have a black 93 Cobra that always draws attention because people think the paint is wet. I also use Zymol on my red lightning, and I like how it makes the paint look deep and glossy. The trick that I have found with Zymol is this - Leave vehicle in the sun to warm up the paint. Bring it inside to wax it using an "X" pattern - up and down on the sides, and left to right on horizontal surfaces. Pull vehicle back out into the sun, and let sit for about 10 minutes. Buff off the wax using a soft towel in the same motion as it was applied. I believe that it is a very durable wax, and protects the paint.
99.5 Lightning
K+N Filter
Tek-Style Tonneau Cover
93 Mustang Cobra
12.90 @ 105 mph
Old Jun 28, 2001 | 07:25 PM
BRIMSTONE's Avatar
Post
Hey guys, I will be trying Zaino for my Cobra R, but, I am trying a product called Klasse on the Lightning. It's an acrylic polymer based polish that lasts up to 14 months. I leave my Lightning parked outside for most of the time and this stuff is REAL REAL good. Even with condensation at night, the water just beads up, no spots! Excellent dust repellent too! I use a coat of the polish and then finish with the sealant glaze. Smooth as glass.
I am curious to see how it compares to Zaino.
