2001 L w/2000 miles SMOKES @ Start up!
My new L W/ 2000 miles just started to smoke at almost every start up about 2 weeks ago.No bad noises no other complaints just that. I guess my only question's are is this BAD, and should I call my dealer?
TY,
YZ
2001 Lightning bell tech, A.R.E bed cover
2000 Ford Excursion
2000 Ducati 996 SPS (for sale)$24,500
1 smashed r6
TY,
YZ
2000 Ford Excursion
1 smashed r6
I only have about 750 miles on my 2001 and it gives a little puff of smoke only on the cold mornings, like below 55 or so. If it is above that it does not and if I wait say till like 10 or 11 am and it has warmed up a bit outside it does not do it either.
I am not sure if it is a problem yet or if maybe it only does it when it is cold if maybe it just is the forged pistons and that extra gap between them and the cylinder wall when cold.
I am not sure someone also said maybe the pcv, but mine works fine.
Like I said it only does it once in awhile and so at this point I am not too woried.
Paul
Paul
My 2001 used to do it. I don't think it has anything to do with the valve guides.. They're brand new! That doesn't make any sense. I think it's the oil return from the valve cover back to the throttle body. Ingested oil puddles and gets sucked in (more so) at start up. I put the JDM oil fill breather filter n' chip mod on mine and have had not one puff-o-blue on start up since.. Just my experience!
2001L, red, born 2/6 and arrived 2/28!!!
JDM chip
crankcase filter
PSP lower blower pulley
12" Big Mouth filter
Magnaflow
Wet Okoles
Bedrug
Pro-Sport Lid
Let the mods begin....
1969 Vette coupe, 496ci stroker big block, aluminum heads, 4340 crank & H-beam rods, JE 10.8 pistons, roller everything, McLeod dual disk clutch w/ aluminum flywheel, Richmond 6 spd, 3" dual exhaust, 300hp nitrous fogger, much, much more.
LS1 eater.. big time!!
1985 FoToLet, work truck, 85 Toyota 4x4 (started as), Reading bed, ladder racks, 8" lift, 33 x 12.5's, Vette 350 4 bolt motor, Hooker Super Comp headers, Ford 9" rear, Toyota front diff, turbo 350 coupled to a Toyota transfer case, 410 gears, a/c & power steering. f-a-a-s-t A/C & heat calls..... my specialty.
web page: http://personal.picusnet.com/undy
JDM chip
crankcase filter
Magnaflow
Wet Okoles
Bedrug
Pro-Sport Lid
