problems
Old Aug 22, 2008 | 11:00 PM
black knight's Avatar
problems
what does it mean when the l just dies and shuts the data (predator) completly off sometimes.
Let me put it to you this way. it will run for like 5 to 10 min's and shut off for no reason. like someone is in there turning the key off
Old Aug 26, 2008 | 02:25 PM
pitstain's Avatar
Can you try to explain a bit more, and also explain what things you have already checked.
Have you pulled any codes from it?
Old Aug 27, 2008 | 03:45 PM
Dbl G's Avatar
I feel that it is your...
Old Aug 30, 2008 | 09:01 PM
It throws no codes. i have been checking other things. I have replaced the battery 3 times, new altronator 2 times. crank sensor, cam sensor, check all of the wireing. it does not lose power. the pumps dont lose power. if anything they stay on sometimes when it dies. i posted the problem that i am having on another fourm, and i though it turned out to be the chip. well after four different chips it finally went away for 2 weeks. and now the problems back. we even tryed a new computer and still the same problem. Well yesterday i decied to check the voltage at the coil's and i was suprised at what i had came across. the voltage at the coils were so out of wack. they were changing so fast i could barly tell what they were. the numbers where high like 20.5, 15.00 07.00 volt's basicilly everywhere. i tryed undoing the battery when it runs and the numbers are still all over the place but the L does not die it ran for a hour with the battey disconected. then i though maybe the altronator had a bad voltage regulator was going bad. so i dissconnect the altro and nothing chnges. the volts to the coils are still going hay wire. so i dont know what the mean. yes he does have a KB boost a spark, but i have it dissconnected so that puts that out of the equation. thats the only thing that i could find very dissturbing. i checked my own lightning and the volts are like 12.9 to 13.5. it verys ofcourse it verys. but not like this. if i can figure out how to get video on here i can show you
