nitrous
Old Jun 25, 2001 | 07:27 PM
L-MATT's Avatar
Post nitrous
what is the setup to get? i want adjustable and i want to purge, does anyone have all the part numbers for the stuff they got and which system is best and why?
Old Jun 25, 2001 | 07:47 PM
RTKILLA's Avatar
Post
Just call up any nitrous express dealer and get the NX EFI kit, with the gen X kit also. that will be everything you want to run some N20 in the beast. I love the NX kit and its the best one out there, everyone hear pretty much uses it.
Also you will need some knew plugs, I would use a NGK TR6 for a 50 shot, and anything higher go with a NGK TR8 or 9. run with the TR8's once and then check the plugs, then go from there.
POWER SURGE PERFORMANCE RULES!!!
Old Jun 25, 2001 | 09:30 PM
StruckBy99's Avatar
Post
L-MATT:
The kit alot seem to use is the Nitrous Express wet kit. Its adjustable from 50-150hp shot.
Part number for the L is 20922.
My opinion is to stay with a wet kit, where the nitrous and fuel are introduced to the intake at the same time.
Black '99 #398 of 4000
13.71 @ 98.2 mph (stock)
13.11 @ 102.8 mph (JDM chip, Pro-M meter, Level 10 converter and shift kit)
Old Jun 25, 2001 | 11:09 PM
L-MATT's Avatar
Post
what needs to be done before i spray? i was planning on a jdm warm weather flip chip (i live in florida),a psp lower pulley, a airaid filter kit, a trans go or level 10 shift kit and amsoil full synthetics through-out, with later plans for cal-tracs, et streets, and the hotchkis kit with sway bars when available, i am planning on running a 100 shot
99 COBRA, DE-MODDED--traded
01 silver L, stock for now
[This message has been edited by L-MATT (edited 06-25-2001).]
Old Jun 26, 2001 | 01:06 AM
HANKFAN's Avatar
Post
Give Jim a call and he can set you up a 100hp nitrous program on the other side of your chip. Enjoy
00 Silver L
Built 3/16/00
Mods:
AAD F-1 Hood
01 Headlights & Tails
3/4 Drop
Eibach Front Coils
Hotchkis Rear Springs
75hp NOS Dry Shot
JDM Nitrous Program
90mm MAFS
JL Air Intake
Oval Bore Throttle Body
PSP Electric Fan
Redline Water Wetter
HANKFAN
