IAT adjuster
Old Jun 22, 2001 | 11:32 AM
irbchman
Guest
Posts: n/a
Question IAT adjuster
does anyone here use an IAT (intake air tempature) adjuster???? Got one on my Ram and it definately helps here in Fl. where it is damn hot year round.
'01 White Lightning <1K miles presently a '97 Ram with a little ol 318 also
Old Jun 22, 2001 | 02:10 PM
Big Poppa's Avatar
Post
Hello all..
I know the guys with the Contours and Focus use those things.. it is really supposed to help the smaller engines.. I suspect it also has alot to do with the computer.. The chip makers should know just how much timming and fuel is pulled for a given temp increase.. if it was big.. I am sure they would have allready done something to counter it..
Got Boost ?
1999 SVT Lightning
Old Jun 22, 2001 | 02:16 PM
awhittle's Avatar
Post
This all sounds dangerous to me. I thought that is what you pay a tuner to do. We used to call that a "dial a brew", but that was in the days that the motor needed more fuel.
AW
Old Jun 22, 2001 | 07:18 PM
NOSTROMO
Guest
Posts: n/a
Post
H3ey irchrbman where did you get that for your ram?
I got a 97 ss/t with a kenne bell blower.....runs pretty good considering it's a dodge! It's har to find performance parts for these trucks..
Anthony
Old Jun 22, 2001 | 07:22 PM
CornerCarver's Avatar
Post
If it's anything like the '99 Cobra's, it adjust the baseline timing by a degree or so. Nothing major. Some guys got ~3rwhp from fooling the EEC by putting a 100k ohm resistor in the IAT socket. 100k ohm fools the computer into thinking it ~40 degrees outside air. I did it and didn't really see any gains.
Old Jun 23, 2001 | 12:06 AM
LIGHTNINROD's Avatar
Post
you mean a FAN?
2001 Lightning, silver, JL chip(street), air intake, & drive shaft loop, escort 8500, ranger 2950dx dual band radio, wilson 2000 ant., bot/picked up on 05/08/01, 1997 f150 xlt 4.6L 4x2 with: a/f one fipk, superchip, optima battery, bbk 75mm throttle body, edelbrock ias shocks--2001 lightning to come(she came--see above)
"nothin' but a bunch a low-life white trash drinkin' too much cheap alcohol"
"I don't take s**t from guys who drive Lightnings," the cop said. "You're speedin' when you're sittin' on the parkin' ramp."
"some days you eat the bear and some days the bear eats you."
Old Jun 23, 2001 | 12:13 AM
irbchman
Guest
Posts: n/a
Post
No it is a reastat or however you spell it . Basically it changes the air temp the computer reads and therefore increases the fuel flow and timing at lower faked temps. As you may have read here most folks say their L runs better when it is about 50 - 54 degrees outside. It is a simple setup and took 15 mins. to install and added a little pep to the "little ol' 318". The current product is Mopars only
Old Jun 25, 2001 | 08:08 AM
irbchman
Guest
Posts: n/a
Cool
Hey NOSTROMO
I got mine from Bernd at www.speedtweaks.net
he is a good guy and is working on a couple of things for Fords as well.
