torque 'em
Old Jun 19, 2001 | 08:05 AM
LIGHTNINROD's Avatar
Post torque 'em
sat. i pulled the left front tire to install my JL ram air kit. when finished, i torqued(95 ft. lbs.?--anyone know the correct torque?) the lug nuts. i then checked the other wheels and found the rt rr. 'loose'--the wrenched moved maybe 3".
so, all you new owners might want to check yours...
2001 Lightning, silver, JL chip(street), air intake, & drive shaft loop, escort 8500, ranger 2950dx dual band radio, wilson 2000 ant., bot/picked up on 05/08/01, 1997 f150 xlt 4.6L 4x2 with: a/f one fipk, superchip, optima battery, bbk 75mm throttle body, edelbrock ias shocks--2001 lightning to come(she came--see above)
"nothin' but a bunch a low-life white trash drinkin' too much cheap alcohol"
"I don't take s**t from guys who drive Lightnings," the cop said. "You're speedin' when you're sittin' on the parkin' ramp."
"some days you eat the bear and some days the bear eats you."
Old Jun 19, 2001 | 08:30 AM
Wyldman's Avatar
Post
For 2000 and 2001 truck, wheel lug torque 150 lb/ft (14mm lugs). For 99's it's 100 lb/ft (12mm lugs).
Hope this helps...
The
<A HREF="http://www.haloclub.com" TARGET=_blank> </A>
99 Black Lightning
12.39 @ 113 MPH
in full street trim
Old Jun 19, 2001 | 01:06 PM
BfB's Avatar
BfB
Banned For Rules Violations
Post
<font face="Verdana, Arial" size="2">Originally posted by Wyldman:
Hope this helps...
</font>
Yeah, but did the '00 and '01 Lightnings have different lugs, compared w/ saying the reg. F150.
BfB
Old Jun 19, 2001 | 02:36 PM
Post
150 ft lbs! damn wyldman, are you sure? that seems way too high.
Old Jun 19, 2001 | 02:43 PM
Baby Jake's Avatar
Thumbs up
Wyldman is correct!
Jake...
Old Jun 19, 2001 | 04:02 PM
4D THNDR's Avatar
Lightbulb
I believe the 150lbs torque is stamped on the lugnut.
Red '00 Lightning,
Power Surge Performance enhanced,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
Old Jun 20, 2001 | 03:42 PM
redlite's Avatar
Thumbs down
Well, a friend of mine has a 2001 and was installing wheel locks, and broke a lug off. He was using 150 lbs on his torque wrench. I understand it takes about four hours to get at and replace the broken lug. The 150 seems extremely high considering the '99 use 100 lbs. with a 12 MM lug. 150 for 14 MM lug? I do'no.
Old Jun 20, 2001 | 04:33 PM
BOSTONL's Avatar
Post
150's what I found when researching specs. Would also recommend retorquing after a few days. Alloy rims are notorious for requiring retorquing.
Ed
White'00 #2006
Old Jun 20, 2001 | 04:56 PM
Spiro99SVT's Avatar
Post
simply GOODENTIGHT works for me
Spiro-THE"GREEK"
12.37 @ 110.15@ 4700lb w/out the Go-Go juice
11.94 @ 115.31@ 4700lb with 100 shot Go-Go juice
11.40 @ 113 @4700lb with 150 shot(on the brakes)NOT BACKED UP 4700 lbs.
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCE
Sales@POWERSURGEPERFORMANCE.NET
MONDAYS,TUESDAYS,WEDNESDAYS,THURSDAYS
@ 302-335-3326 10 a.m.ET-6 p.m. ET
VISIT TEAM POWER SURGE
Old Jun 20, 2001 | 05:56 PM
BfB's Avatar
BfB
Talking
<font face="Verdana, Arial" size="2">Originally posted by Spiro99SVT:
GOODENTIGHT</font>
What do you call a German virgin?
Old Jun 20, 2001 | 06:00 PM
Spiro99SVT's Avatar
Post
LOL.... good one
Old Jun 20, 2001 | 06:41 PM
clonetek's Avatar
Wink
i use the two-grunt© method.
tighten till you grunt once..
get a better grip, then tighten till you grunt again.
if you fart, you've gone too far. check your shorts & start over.
brooks
'00 silver "L"
my zing albums - _-click here-_
clonetek@jam.rr.com
Old Jun 21, 2001 | 06:52 AM
Baby Jake's Avatar
Talking
Good method Brooks!
Later,
Jake...
Old Jun 21, 2001 | 04:19 PM
clonetek's Avatar
Post
baby jake cant use my method.. he doesn't weigh enough!
well, maybe if he was holding a couple cases of beer.. oh wait, he always has beer!
Old Jun 21, 2001 | 04:42 PM
Jay Lincoln's Avatar
Post
Typically, the 14mm studs are used on the 3/4 ton trucks, and use 150 lbs. On our trucks, they say to use this amount.
Have you ever tried to untorque a lugnut at 150 lbs. why the wimpy wrench they give you for changing a tire? Good Luck. Time to call AAA.
I've been using 120 lbs, and have had no problems.
