New noise after lower pulley install.
Old Jun 20, 2001 | 09:16 AM
LIGHTNINROD's Avatar
Post
madhouse: i think it was one of my posts that referred to this slightly longer s/c belt. that is the correct number. it is a Gates belt and i bot it at a NAPA store. the clerk told me to 'drop' the 'k'? but that is a good no. i like the idea that the s/c bearings aren't being overstressed by a too tight belt.
<font face="Verdana, Arial" size="2">Originally posted by Madhouse:
I went to three different places looking for a belt that's supposed to be a little longer. It was posted here, part number K080670. They told me that there must be more to the belt number - nobody could find that particular belt.
</font>
2001 Lightning, silver, JL chip(street), air intake, & drive shaft loop, escort 8500, ranger 2950dx dual band radio, wilson 2000 ant., bot/picked up on 05/08/01, 1997 f150 xlt 4.6L 4x2 with: a/f one fipk, superchip, optima battery, bbk 75mm throttle body, edelbrock ias shocks--2001 lightning to come(she came--see above)
"nothin' but a bunch a low-life white trash drinkin' too much cheap alcohol"
"I don't take s**t from guys who drive Lightnings," the cop said. "You're speedin' when you're sittin' on the parkin' ramp."
"some days you eat the bear and some days the bear eats you."
Old Jun 20, 2001 | 09:22 AM
JeffsLightning's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by LightningTuner:
2. It could be a tensioner problem. If you unbolt the intercooler tank and lift it off to the side, you will see the blower belt tensioner. If you look closely, you will see a small casting nub that sticks off, and actually stops the tensioner arm from moving at one point. When you install the pulley, which is larger, it moves the arm closer to this nub. On some trucks it will actually hit the nub. You can snap this nub off by putting your breaker bar on the the tensioner and moving the arm until it contacts the nub, and then using a bit of force, snap the nub off. This will give you more tensioner arm throw, and if you do this BEFORE you try to put the belt on after you install the pulley, the belt goes right on. there is no harm is removing this nub, is it used for prodcution assembly only.
</font>
Sal aren't those nubs for limiting the tensioner arm from moving to far when there is no load on it? If I were to remove them I think I would just use a dremel. Aluminum arms bend too easy.
DRIVE IT LIKE YOU STOLE IT!
hud@mc.net
Old Jun 20, 2001 | 09:24 AM
Madhouse's Avatar
Post
OK, thanks Lightninrod - I'll give it another try elsewhere. I'm hoping to get my pulley next week...
Old Jun 20, 2001 | 09:44 AM
Post
I'll give it another try elsewhere. I'm hoping to get my pulley next week...</font>
Try to go to a Napa store. They had it in stock when I went there..
hud@mc.net
Old Jun 20, 2001 | 10:15 AM
RTKILLA's Avatar
Post
You know I have experienced this sound as well, but only once the truck has been running for about 15 minutes and everything is heated up. I think its that nub now that you say that sal, its makes sense because my belt would loosen up a bit and then make that noise. I couldn't figure that out for the life of me. I'm going to try and fix that tonight now. Thanks a million Sal!!!
POWER SURGE PERFORMANCE RULES!!!
Old Jun 20, 2001 | 10:42 AM
ally69's Avatar
Post
Anyone have pic of these nubs? or were they were?
2000 Red
Speed Grilles
Clear Corners
01 Tails
Old Jun 20, 2001 | 04:35 PM
4D THNDR's Avatar
Post
OK, thanks Lightninrod - I'll give it another try elsewhere. I'm hoping to get my pulley next week...</font>
I tried Autozone, Twin B, Pep Boys, and Advance Auto before finding out that only Napa carried the Gates brand.
Red '00 Lightning,
Power Surge Performance enhanced,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
