Air Box Mod ??
Old Jun 18, 2001 | 08:30 PM
ally69's Avatar
Post Air Box Mod ??
First my truck is bone stock I did the air box mod holes in bottom and k&n filter And I Did pick up some boost and it gets into the supercharger a lot faster but. It seems I lost a lot to low end could easaly roast tire before no not so much and from a roll about 30 or so it does not seem to do shift hard like it used to is the from the mod or more likly the mosterous heat? about 93 in missouri today? Or will it take some time for cpu to adapt? Thanks
2000 Red
Speed Grilles
Clear Corners
01 Tails
Old Jun 18, 2001 | 09:38 PM
HIGH ROLLER's Avatar
Cool
ally69,
I have done testing with my open filter kit against my stock airbox with a K/N filter only and the stock air box performed much better than the open one did on my truck.Just a few days ago i put a 4 1/4 inch circle hole in the bottom of my box and ran 4 inch flex hose to it for ram-air and it is working fine so far!
For best results you will have to keep the engine heat away from the filter.By cutting holes in the bottom of your box you are picking up more boost but running slower times just like the open filter because of the engine heat.Just run a flex hose to your box so it seals up from the bottom and all you will get is the outside temperature air coming into the bottom of your box and still is enclosed.This is just my opinion that i feel my truck runs best with this setup!!
Matt
Silver01
12.85
109.40
Old Jun 18, 2001 | 09:43 PM
Don C's Avatar
Post
here is what I did
Works awsome, in hot weather it is the ticket
http://donf150.tripod.com/Welcome/id6.html
http://communities.msn.com/MyFordF150&naventryid=100
13.11 @ 104MPH
Old Jun 18, 2001 | 09:58 PM
Thumbs up
Don C,
Thanks for posting pictures for all to see.Your setup looks like mine except i run my hose at the bottom of the grill!
Old Jun 18, 2001 | 10:37 PM
REDHOTL's Avatar
Question
Don C, what did you use for a flange to slip the flex over? Also, do you run that black plastic funnel up against the front grill and not the open tube as shown in the front grill picture? Thanks.
Old Jun 18, 2001 | 10:40 PM
REDHOTL's Avatar
Post
Don C, I looked a little closer, I can now see the black funnel in the grill, tough to spot. What dia. flex did you run?
Old Jun 18, 2001 | 10:43 PM
Smile
It looks to me like he ran a 3 inch flex,it is a very tight fit to make a 4 inch work!
Old Jun 18, 2001 | 10:48 PM
awhittle's Avatar
Post
Please post photos of how to get a 4" hose thru ther engine compartment and to the grill
Andy
Old Jun 18, 2001 | 10:58 PM
Post
Andy,
KGM posted some pictures the other night on 6-15 that showed how he ran a 4 inch underneath,this is how my setup looks.I do not know if it is possible to run a 4 inch up to the grill like Don did,it is awful tight up in that area!
Old Jun 18, 2001 | 11:34 PM
Don C's Avatar
Post
REDHOTL
Ya it is a 3" hose, I still have to remove the grill and route the hose better, which should make it work even better.
