Anyone who lowered there truck. Help out please.
What Spike said is correct.It all depends on the uses of YOUR truck.And what you want out of it.I know if you lower the back 2 inches and relocate the battery to under the truck your ft to rear is changed almost 2% to the rear.Pinion angle is a big factor if you have a huge angle you are using hp to turn the shaft as well as a vibration.As for brake bias you can run a more aggressive pad on the rear[to get more brake] and a stock or medium pad on the ft.By doing that you will help in resisting fade and have a more neutral braking vehicle.There is alot more than that too,ie. brake dive,scwat[sp],steering angles and turning angles plus the angles of your sway bars affect how your truck can and will handle.Stan
I other words buy a kit that keeps all that in prespective.Don't try and do it the cheapest way do it the right way!
