What 1/4mile times is normal for a 2000
Old Jun 10, 2001 | 05:40 PM
CLIFFSRAMAIR's Avatar
Question What 1/4mile times is normal for a 2000
I just brought my 2000 Lightning to the track Friday night. Has 3000 miles. The temperature her in Oklahoma was 90 degrees. Humidity was 100 percent,(it just rained before my runs) with a 5-10 mph head wind. Anyway, I ran (3 times)@ 14.5 sec with 2.21 sixty foot times at 95 mph. What I was wonder; is this normal for my truck with these weather conditions? This is my first time to run this truck and the first time to post on this sight. I was disappointed with the time because several of my friends with there T/A's were ragging on my times. Also a 2001 Lightning was running consistant 14.6 at 95 to 96 miles per hours which is much slower then everything I have read. Please give me so input.
Old Jun 10, 2001 | 05:51 PM
zbornac's Avatar
Post
from what I can tell is that most of it was in your 60'. 2.21 is pretty bad i think. I have never ran mine so i'm not sure for sure, but I think most people on here get 1.8-1.9 60'. just my .02
'00 Black L'
AFTERMARKET STEREO: Memphis ST1000D amp(1100w@1ohm), Memphis ST3004 amp (75Wx4@4ohm), Memphis PR93 3-way 6x9's (Front), Fultron 2-way 5x7's (Rear), 2 Memphis 15-ST104D (10"Dual Voice Coil Subs), Custom Vinyl boxes and amp rack, Cascade Audio and Dynamat Xtreme Dampening Material in Doors and back of cab.
PLANNED MODS: Many Many Performance mods, Kenwood KVT-910DVD, Lightning Audio Stiffening Capacitor, A.R.E. LSII Bed Cover (possibly with a Fiero wing), BedRug Bed Liner, Clear Corners, Powdercoated Billet Grill, 'Vader' Custom License Plate, Window Tint, ?20 inch rims?, more, more, more....
IT'S ALL ABOUT THE FUNDS!!
Old Jun 10, 2001 | 06:01 PM
Post
This truck is stock with stock tires. I'm sure the 60 ft time would be much better with Nitto's or M/T on the Lighting. What I'm not happy with, is the 95 mph and 14.5 sec's. I know lower 60 ft times is directly related to lower 1/4 times. But a 2.21 60 ft time should not produce a 14.5 1/4 time?
Old Jun 10, 2001 | 06:06 PM
Silver-Bolt's Avatar
Post
Your 60' time is killing you and the weather conditions suck. Try leaving at an idle or just slightly about. Stay out of the water box. Just enough burn off to clean the tires. Just barely turn them over. Stage it and go. My 2000 stock did 13.82 but the weather was much better. Now it has done a 13.16 with a 1.94 60'. All on stock tires.
2000 Silver Lightning 13.16 (so far)
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
F-250 Trans pan
MagnaFlow 12468
Snug-Lid
I feel a 12.xx coming on.
Team PSP West
Old Jun 10, 2001 | 06:09 PM
Silver_2000's Avatar
Talking
CLIFFSRAMAIR
The weather you ran in was awful. Your 60 ft times were almost awful. Plus a headwind. It would be tough to find worse conditions. Together they can easily cost you 5 tenths.
Practice launches and go to track when weather is cooler and traction is better. You should be able to bust into the 13's with the right weather and launch.
Dont let the smack talk get to you, you will get your share of kills. Good Luck
Doug
Picked up Silver 2000 Lightning 2/28/00!!
1st run 13.9 sec 1/4 !! Best Run 13.025
Silver_2000@SVTLightnings.com
www.SVTLightnings.com
2000 Lightning, FMS 3.73 gears ( Expensive ), PSP 4 Way Chip, PSP Intake, Valentine 1, Snuglid, Bedrug, Lighted Ford Logos, Superchip R9, and 3m Panther Black nickel tint, Clear corners., Boston Acoustics 5x7s and Components, Alpine v12 5 channel Amp and JL Sub, Chrome SVT Rims and G Force R1a Autocross Tires, .
Link to my profile because the UBB doesnt support semicolons any more
[This message has been edited by Silver_2000_! (edited 06-10-2001).]
Old Jun 10, 2001 | 06:45 PM
retics4me's Avatar
Post
i took my 2000 to the track for the fist time saturday . it was raining in the morning and the humidity was up there . i couldnt hook up at all my 60 ft times were like yours .and i only ran a 14.0 .and thats with a chip and filter . i even put on drag radials and that didnt help .i tried to launch every which way but couldnt hook up . i was kinda bummed out but hey theres always next time .
Its not how fast you go its how fast you get there!
silver 00
99 flht
Old Jun 10, 2001 | 08:12 PM
TomG's Avatar
Post
My L is bone stock, and your times don't seem out of line for the conditions. I ran one 13.77 and one 13.85. But these were on crisp cool (60 degree) nights. On a 75 to 85 degree summer night I run usually between 14.0 and 14.1. Also, my best MPH was 99, but I usually run about 98 MPH.
Old Jun 10, 2001 | 08:19 PM
Post
Thanks for the chin up information. I know the street talk is wonderful about these trucks and that is why I bought it. I'm happy I did because it's a much stronger and smoother running truck then my f150 extended cab. I don't plan on racing the L or running at the track, but I did want to see what my L would do. I think maybe this fall when the weather is perfect I will try again.
Old Jun 10, 2001 | 10:28 PM
Ford 2001 SVT F150's Avatar
Post
Cliff,
Did any of the F-Body boys giving you a hard time post any runs in the same night, under those conditions? If they had've they'd have been really quiet about their times. I've seen .7 sec. difference in my 00 C5 6 speed from one week to another due to minor weather changes. The conditions you were in would have affected the F-Bodies badly as well. I've only made 2 passes with my 01 L, both when completely stock & less than 1K miles. The temp was in the low 60's w/fairly high humidity & both passes were in the 13.5 range. 1st run: 13.56, 2nd run: 13.50. As you develop your launch technique & get some good weather you'll get in the 13's soon enough.
Old Jun 11, 2001 | 03:00 AM
Peter B's Avatar
Post
First time I ever took my 00 L to the track (1250 feet altitude, 80+ degree weather and no head wind), made 3 passes:
2.287/14.478/96.22
2.251/14.428/95.92
2.193/14.356/95.88
2.182/14.466/95.02
These were bone stock with 250 miles on it.
Then this winter when it was about 60 degrees I ran these type of times:
2.106/13.884/99.331
2.131/13.952/99.053
2.078/13.824/99.79
Sounds like your times are right on the money considering your conditions. I don't even go to the track anymore until winter when its 50-60 degrees out. Don't be dissapointed in your times, the weather, the head wind and your launch are all factors in your not what you expected times.
Old Jun 11, 2001 | 03:44 AM
GreazedLightning's Avatar
Post
Cliff, where you from and where did you run at? Shoot me a email and maybe we can get together some Friday night at ThunderValley in Noble. - Rick -
- Rick -
00 Black Lightning
#3395 on 5/30/00
Stull Billet Grill
Clear Corners
Line-X Bed Liner
JL Stage II Ram Air (on order)
Old Jun 11, 2001 | 07:24 AM
Madhouse's Avatar
Post
My 2000 ran a 13.68 with just a Pro-M MAF, but in much better weather conditions...
<A HREF="http://users.ev1.net/~temurphy/lightning/" TARGET=_blank> </A><A HREF="http://haloclub.svt-lightning.com" TARGET=_blank> </A>
2000 Black Lightning
#4399
Old Jun 11, 2001 | 08:51 AM
J MAN's Avatar
Cool
Like all have said the performance of the L's are very much related to temp and humidity.The times you mentioned are very typical.
Old Jun 11, 2001 | 09:19 AM
Catman's Avatar
Cool
Its just the weather Cliff,I live In North West Florida and runs are off as much as 4tenths on the high humitity nights.Your truck Is fine.Mine also ran better after It got more miles on It. Lawson
Old Jun 11, 2001 | 05:05 PM
redlite's Avatar
Post
Do you know what the barometric pressure was?
Apparently, the pressure is key too. Some of the regular racers on the Board don't even bother to race unless the pressure is 30 or above.
