Bassani Exhaust Questions
I just picked up my '01 White Lightning and still breaking it in. I have read here that several of you have put in the Bassani exhaust and said it did not do any good; one of you said you wee going to remove it. My questions are:
1. Did you install the FULL Bassani system? Headers, X-pipe, hi-flo cats, etc. or just a cat back?
2. Did you pick up any MPG?
I put the full system on my '93 L and it worked VERY well!
1993 Lightning,Complete Bassani,FoMoCo mass air conv,K&N,Bilsteins,pheno spacer, roller rockers
1994 Pace Car,full Bassani, K&N
'00 box stock
[This message has been edited by Zap (edited 06-10-2001).]
'00 box stock
I believe you can purchase the components seperately, but probably not cost effective if you will eventually buy everything. Good for sound, not much else. I think it sounds real deep and throaty...big block sound.
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
New times w/ converter coming soon!
Awful lot of money for just sound.On a supercharged engine exhaust doesn't come Into play as much as a carbed engine,unless Its stoped up really bad.The cross over pipe or X pipe and a good muffler will give you the same results. Lawson
You know everybody complains about how much money the bassani kit costs, but look at what you get for $1700. stainless steel ceramic coated equal length headers, all stainless steel pipes and collars, stainless steel cats, and mufflers, stainless steel x pipe and chrome bad *** exhaust tips. Any exhaust that consist of that kind of quality parts is going to cost that much. sure it doesn't do to much for a bone stock L, but I'm sure that the bassani system does help out with guys like us that are pushing over 400 rear wheel hp, ans also the few of us that are spraying the trucks as well. I love the way to bassani sounds and I'm sure it does help out some. The only thing I would do different would be the long tube headers, cause it is a fact that the long tube headers do help out with the low end trq on these trucks.
Powered By: POWER SURGE PERFORMANCE Products.
www.powersurgeperformance.net/ubb/cgi-bin/ultimatebb.cgi
Not Complaining,just think Its not a good first mod.After you go far enough to justify a new system It Is as good choice and a quality product.
I appreciated the feedback. Both Basanni systems I've put on fit well(no torch, hammers, Moto tools, etc. needed), but both were on push rod engines, and they helped a bunch.
I don't think Bassani has full length for the L.
Is the Bassani system CARB approved like the 5.0 and 5.8 ltr versions?
'01 box stock
'01 Saleen S281SC Speedster
'01 box stock
RT: your L needs more low-end torque? pshaw! hehehehe
2001 Lightning, silver, escort 8500, ranger 2950dx dual band radio, wilson 2000 ant., bot/picked up on 05/08/01, 1997 f150 xlt 4.6L 4x2 with: a/f one fipk, superchip, optima battery, bbk 75mm throttle body, edelbrock ias shocks--2001 lightning to come(she came--see above)
"nothin' but a bunch a low-life white trash drinkin' too much cheap alcohol"
"I don't take s**t from guys who drive Lightnings," the cop said. "You're speedin' when you're sittin' on the parkin' ramp."
What about MPG? Does the Bassani do anything for the fuel efficiency side.., I know they are loud. On my '93 L the system gave me about 20% gain in fuel economy( fron 10 to 12)
1994 Pace Car,full Bassani, K&N, 3.73, pulleys
2001 Lightning, box stock
2001 Saleen S281SC Speedster, box stock
I've got (or had) the bassani full system and to be honest I would not recommend it at all. After about a year of service both cats went to total *****. Causing my truck to run horrible. I recently had the cats adn mufflers yanked off. Guess what drivers side cat was hollow, repeat crystal clear nothing in it. The passenger side cat had a nice big brick of the catalyst wedged into the outlet end of the cat, effectively killing all flow. I replaced this with 2 new hi-flow cats and a 2 flowmaster 3 chamber mufflers. I noticed and immediate gain of 200+ horsepower and no bogging/bucking/backfiring/spitting/pucking/etc from my truck. I would really really consider doing something else with your 1700 bucks. If I were you go for a dyno tune chip (about 350), pro-m MAF, and for sound add a set of mufflers on the back in place of the factory set.
btw...when I had my bassani put on I gained about 8rwhp on the dyno. My chip gained about 30-35rwhp and the pro-m was worth another 29rwhp. In the end my 99L put out 378rwhp and 442rwtq and this was with a very early chip. I am sure with one of the newer burns more is to be had, but I'm happy for now.
good luck either way
Mike B.
Mike B. '92 GT, '00 GT, '99.5 Lightning
Houston Performance Chip
Pro-M 80 MAF
Bassani Full exhaust
Best ET 13.16@103.84
Mike B.
Pro-M 80 MAF
