interior question
Old Jun 6, 2001 | 11:36 PM
72smitty's Avatar
Post interior question
I am currently working on a custom subwoofer and amp rack enclosure for my 2000L and have already removed the changer and storage bin. I was wondering if anyone knows how to remove the mounting bolts from the floor behind the cab. Are they welded, bolted, or something else? Thanks for any help.
Old Jun 7, 2001 | 07:25 AM
JHCain's Avatar
Post
Greetings;
Those bolts are studs, tack welded to the floor.
I ground mine off flush to the floor. If you work 'em back and forth with a pair of vise-grips clamped on, they will eventually break off. And leave a 3/8" hole in your floor. Which is probably less than optimal.
Cut them off as close as possible with a hacksaw or flexible sawzall blade, then grind down what's left offending you.
-Jim
Jim Cain
JHCain@raising-cain.com
White 99 Lightning
Black 00 BMW M Coupe
http://www.averagegeek.com
Old Jun 7, 2001 | 08:34 AM
clonetek's Avatar
Lightbulb
use a "dremel" type tool with a fiberglas reinforced cut off wheel.. have a vaccume cleaner handy, and watch out where those sparks go. lol
brooks
'00 silver "L"
my zing albums - _-click here-_
clonetek@jam.rr.com
Old Jun 8, 2001 | 06:55 PM
72smitty's Avatar
Post
Thanks guys for the info. I thought they looked welded, so I guess the best way to fix this is cut them off and grind them. Thanks again!
