Best place to buy splitfire
Old Jun 4, 2001 | 10:16 AM
FASTBOLTofLIGHT's Avatar
Post Best place to buy splitfire
Where can I get splitfire for the best price for my lightning
FASTBOLTofLIGHT
99.5 Lightning
Downs intake
Superchip R9
Slotted Rotors Front/Rear
Lo Pro Tonneau
Netro wing
Boost & Oil gauge
and soon 2001 look
the faster the better zoomzoomzoom
Old Jun 4, 2001 | 10:55 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Post
**donning nomex**
Don't buy them. Go with NGK's or Autolite 103's. My Splitfires left with the garbage man last Wednesday.
I know of an owner that had the bottom half of a Split' break off and destroy his motor.
Play it safe as getting an L motor in the P.I. would be a biotch.
[This message has been edited by Speedin Bob (edited 06-04-2001).]
Old Jun 4, 2001 | 11:09 AM
DUCK01's Avatar
Post
I'm with SB. Go with the NGK TR6s from www.internetracerssupply.com . Everyone seems to have more luck with them. Just my $.02.
DUCK
November 18, 1999 We will not forget.
The fallen 12 will live in our hearts forever.
Fightin' Texas Aggie Bonfire 1999
[This message has been edited by DUCK01 (edited 06-04-2001).]
Old Jun 4, 2001 | 11:32 AM
Post
Speeding Bob and DUCK01
Thanks for the info. I will be ordering the NGK now I need to know do you have any info as to the rotors we have in the front are they from a F250 as i kind of remember some one say it is from the F250 is this true need to change my rotors for the 4th time cracked them all the heat the speed and the traffic is all the cause of this
99.5 Lightning
Downs intake
Superchip R9
Lo Pro Tonneau
Netro wing
Boost & Oil gauge
and soon 2001 look
Old Jun 4, 2001 | 11:39 AM
ib fast's Avatar
Wink
More ngk plugs have burned off than any other brand plus they don't do squat.This is total misinformation and i have had splitfires for 14k.
Old Jun 4, 2001 | 11:41 AM
99svtlightning's Avatar
Post
Why not use stock plugs? They have taken many into the low 12's for 40 thousand miles.
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
Old Jun 4, 2001 | 01:55 PM
Post
I cannot comment on NGK's, I don't use them but I don't think it is misinformation that a Splitfire broke and torched a motor. It happened.
Like I said, I had Splits in my truck and was satisfied with them but removed them as I had a low RPM miss that turned out to be part of the chip tune.
Thanks, but I'll play it safe with Autolites.
Old Jun 4, 2001 | 02:49 PM
ib fast's Avatar
Cool
Speedin bob, i was not questioning your post, only that ngk should be used as a safer alternative.I do not recommend any brand on the boards as most that change plugs also have chips and other mods and these are the trucks that are burning plugs.You do not see stock trucks burning plugs and you also don't see anyone posting that while on the juice they burned a few ngk plugs.They only say there plugs melted. This is what i was reffering to,fact is no plug is exempt from this when your modded.
Old Jun 4, 2001 | 03:06 PM
Smile
no flame/offense taken ib.. just trying to look out for our buddy in the P.I.
Old Jun 4, 2001 | 03:27 PM
LTNBOLT's Avatar
Cool
Speedin Bob,
Who's chip are you running to give you the miss you talked about?
Who broke their motor? I don't remember it being post here. I remember Doug breaking 3 splits but it didn't take out his motor.
Later,
Chuck
Black 00
Chuck's Lightning Page
Old Jun 4, 2001 | 03:44 PM
DJANIMATE's Avatar
Post
I run the splits and could feel a real change in throttle response as soon as I installed them. I've randomly checked the plugs for irregular burn and have found nothing negitive. My 02.
Adam
01 Black Lightning - JDM 'FlipChipenfiltered','Straightpiped', 'splitfired', 'billetted', 'Neoned', and 'Grooved' thanks to Blaupunkt, Alpine, Sony, Clarion, Dynomat, and MTX
Old Jun 4, 2001 | 04:28 PM
Arrow
Chuck,
I'm currently running JDM's "summer program" From what I gather, tested, and confirmed (with and without Splits), the "miss" occurs when cruising steady between 1300 and 1900 RPM's. I hope this can be addressed with a reburn. Otherwise, time for something else as it is annoying and unacceptable for my driving style.
As far as the individual torching their motor and no flame intended, I'll let them decide to post the details if they feel it appropriate. It is there perrogative and not my place to do so.
Bob
Old Jun 4, 2001 | 05:30 PM
lightning Jeff's Avatar
Post
speedin bob, I just sent my chip back to the tuner cause of a miss I was having. I pulled the chip out and it was gone. Put the chip back in and it was back. It was also at a low to mid RPM. It was not the JDM chip though.
Old Jun 4, 2001 | 06:14 PM
HIGH ROLLER's Avatar
Cool
Here is my take on this,i have had the NGK TR6 plugs in 2 different times on my 99 L and both times i had detonation with them after install and had none with the stock platinums!I know alot of people use them but i feel they are very overrated and no better throttle response!I also installed the splitfires and right away noticed better throttle response but i also had 2 break on me that i believe now was because of lean conditions of my chip at the time i had the splits in.I feel the ngk's might hold up longer than the splits under stress,but if you run safe with no detonation i would go with the splits anyday!On my 01 i am leaving the stockers in because i have never had a problem with them on my 99 and now 01!
Jeff,
I see where you sent your chip back to Danny,was that your miss the other night you were having?Is he going to give you a reburn?Did you get your plugs gapped to the right size yet!Martin Dragway is delayed this weekend for opening night due to the rain we had and will reopen next wednesday night the 13th!
Matt
Old Jun 4, 2001 | 06:23 PM
gforce's Avatar
Post
I'd love to try the Splits myself, but I'm hesitant in trying much of anything the way my engine has been sounding lately.
