Small cloud of smoke on start up???
Old Jun 4, 2001 | 07:16 AM
Undy's Avatar
Question Small cloud of smoke on start up???
I've noticed that infrequently I get a small cloud of blue smoke on start up on my 01. I've got 5K on it and it's been doing it for 2 or 3K miles. No noises or poor performance accompanies it. It does it maybe 1 in 20 start ups. It does it on a warm and cold starts alike. It, by color, appears to be oil related. I don't know if I should be concerned or not... Does anyone else experiance this. BTW, The inside of my tips are sooty but not greasy. No oil consumption between changes too.
2001L, red, born 2/6 and arrived 2/28!!!
JDM chip
12" Big Mouth filter
Magnaflow
Wet Okoles
Bedrug
Pro-Sport Lid
Let the mods begin....
1969 Vette coupe, 496ci stroker big block, aluminum heads, 4340 crank & H-beam rods, JE 10.8 pistons, roller everything, McLeod dual disk clutch w/ aluminum flywheel, Richmond 6 spd, 3" dual exhaust, 300hp nitrous fogger, much, much more.
LS1 eater.. big time!!
1985 FoToLet, work truck, 85 Toyota 4x4 (started as), Reading bed, ladder racks, 8" lift, 33 x 12.5's, Vette 350 4 bolt motor, Hooker Super Comp headers, Ford 9" rear, Toyota front diff, turbo 350 coupled to a Toyota transfer case, 410 gears, a/c & power steering. f-a-a-s-t A/C & heat calls..... my specialty.
web page: http://personal.picusnet.com/undy
Old Jun 4, 2001 | 08:13 AM
GalaxyEng's Avatar
Post
Mine does the same thing
GalaxyEng
2000 RED #2926
13.2@104
BedRug
Haig custom mats
PSP Filter
PSP 4-way
Pro-Sport Tonneau
Old Jun 4, 2001 | 09:44 AM
HTRDPUP's Avatar
Question
I noticed blue smoke when I followed my brother when he was driving my L (I blastphemed, I know!!!) It was very noticable but it dissipated fairly quickly.
When I called SVT, they explained that since the 'puter runs a rich fuel mixture, that if the truck is run fairly hard and then gets shut off for a while, that sometimes a condition is created called "fuel wash". This is when unburned fuel is sitting in the cylinder after shut down. I was told to idle the truck for a couple of minutes before shutdown and that should burn any excess fuel. I know idling for a couple minutes, concerning a turbo charger, is needed to stablize the oil temp, to prevent coking. But this is not the case for a supercharger. I always thought that blue smoke was a sign of oil burning, rich fuel mix burns black. I dunno, I think I am getting a line from SVT.
NEED MORE POWER
Old Jun 4, 2001 | 10:30 AM
Silver-Y2K-SVT's Avatar
Post
I often get a LOT of white smoke shortly after start-up. Usually right after I back out of the driveway, put it in "D", and stomp the loud pedal through the firewall. Is this normal?
Silver Y2K Lightning
Bone Stock w/ Duraliner, Ford Hitch Cover
Best 60-foot: 2.041
Best 1/8: 8.872
Best 1/4: 13.789
Best MPH: 99.67
Silver (matching) Y2K ML320 Benz
Burl (ML430) Shift ****
Best Run: 17.137@80.629 (2.550 60-foot)
1992 Grand Prix SE
Commuter Mule, G-Tech 17.3 @ 81
Old Jun 4, 2001 | 03:27 PM
redlite's Avatar
Smile
Got a '99 with about 14500 miles. I get the smoke cloud too on start-up, but vary rarely. Usually see it on on cold or cool mornings after the truck sits outside all night or longer. Pretty good size cloud of blue smoke and it smells oily. Engine has rattle noise too in the morning almost sounding like a diesel engine . Rattle goes away after a bit.
I just assumed smoke was result of blow-by. No measureable oil consumption so far.
Old Jun 4, 2001 | 08:52 PM
BRIMSTONE's Avatar
Post
I used to get the cloud on my 99, only after it had been stored for a while. Wasn't using oil though and never had problems (besides I/C).
Old Jun 4, 2001 | 08:57 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Post
GOD HELP US ONE AND ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!1
1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Better 1/2 : 92 Red T-Bird.
Old Jun 4, 2001 | 09:16 PM
Jay Lincoln's Avatar
Post
This is pretty typical of oil leaking past the valve seals. It occurs when the vehicle sits for a while and then is started. The high vacuum during idle will sometimes pull oil down past the seals, creating a short puff of smoke.
Typically found on Chevy's with "O" ring valve seals or the umbrella type that have dried out and cracked.
Red 00"
Pro-M mass air
Swanson chip
Aluminum driveshaft
Jay Lincoln homemade
traction bars
*******'s bed cover
Wet Okoles
Lightning floor mats
Email: jaylincolncobra@aol.com
"UNLESS YOU'RE THE LEAD DOG, THE VIEW NEVER CHANGES"
http://www.zing.com/album/?id=4292716723
Old Jun 4, 2001 | 09:32 PM
XanMan's Avatar
Smile
What about the oil that sits in the intake?The build up gets pretty heavy in there from what I've seen.The PCV vent tube that goes from the driver side valve cover to the intake sucks oil at WOT and just sits in there until it gets sucked into the engine.Just a thought.
99 Black F150 4x4 4.2
Powerdyne SVO BD11-a Supercharger
12lb. of boost
24 psi.high flow fuel injectors
Port matched intake
Boost gauge 30"HG-20PSI A pillar mount
K&N air filter
JBA Headers
True dual exhaust with X pipe w/Flowmasters(2 1/2 in. pipe)
custom programed Superchip(Flip chip)
All black factory sport package.
Rhino Liner
GTO smoke headlight&tailight covers
limo tint
Old Jun 4, 2001 | 10:03 PM
gforce's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by redlite:
Pretty good size cloud of blue smoke and it smells oily. No measureable oil consumption so far.</font>
<font face="Verdana, Arial" size="2">Originally posted by Jay Lincoln:
</font>
All right, I can't stand it any longer. I've seen this post all day long and put off replying because I know you guys get sick of my posts, but I can't help it. Jay is absolutely correct - startup smoke is a valve problem. It's either the seals or poor valve guide clearance. Neither one will cause a big oil consumption problem. Just an embarrassing blue cloud when you fire it up after sitting for a while. How do I know? My Vette did it horribly until I rebuilt the heads and so did my 318 Mopar engine. It's pretty universal on piston-driven engines, no matter the make. The oil in the valve guides settles and gets "sucked" down into the combustion chamber upon startup, thereby causing the momentary blue smoke until it burns off. Bad rings will smoke when you "stomp it." Hmmm, which do you prefer on startup, a rattle like I have, or blue smoke? Is it 1950 again? Nice job Ford.
[This message has been edited by gforce (edited 06-04-2001).]
Old Jun 4, 2001 | 10:43 PM
Lightfootning's Avatar
Post
I know that in the past Fords pushrod motors are notorious for leaking valve seals. They get hard and brittle, and break into little pieces. It is not at all uncommon to have the rear oil gallys plugged with pieces of the valve seal on old high mile motors.
My question is... what sort of valve seal, design and material... is Ford using on the cammers?
Old Jun 5, 2001 | 02:07 AM
BfB's Avatar
BfB
Banned For Rules Violations
Post
My old black '99 I just traded in today on a silver '01 does this occasionally.
Not everytime, but sometimes. My motor had the "dieseling" effect at low rpms as well.
BfB
