The Aftermath of Smokin' em
Old Jun 3, 2001 | 12:32 AM
HyE_BoLt's Avatar
Post The Aftermath of Smokin' em
Went for a little cruise today and got a little on the wild side. Laid down the tracks of the L, if u know what i mean. I pull in the garage and see all of the asphalt and rubber caked on the back ground effects. What do you people use to take this ish off?? It seems pretty caked on their and a wet rag didn't work the least bit to remove it.
Old Jun 3, 2001 | 01:37 AM
Spike Engineering's Avatar
<font face="Verdana, Arial" size="2">Originally posted by HyE_BoLt:
... What do you people use to take this ish off??</font>
I use soap and water with a chamois.
Regards,
George
george@spikeengineering.com
http://www.spikeengineering.com
Red 2000 Lightning, #4033
1967 CJ-5 (0 - 3 mph: yes)
White 1996 Whippet (600 yard course, 6 turns: 40 Seconds)
Red Wheaton 1995 Ridgeback (1/2 loaf of bread, 6 bites, 4 seconds)
New addition:
2001 RR Puppy: 0 to stumble - next two months
Old Jun 3, 2001 | 08:13 AM
Fast Gator's Avatar
Cool
Two words....WD-40
1999 Black Lightning... 1940 of 4000... Traded for: 2001 Silver Bolt... Adopted 3/24/01... Red Line Water Wetter... Wet Okole's... Bed Rug... JL Stage II Ram air... Chipless in Jersey
Old Jun 3, 2001 | 10:41 AM
HyE_BoLt's Avatar
Post
I went out to find some stuff that would do the job and came across a "Bug and Tar" remover. This did the job after about 5 times of spraying it and letting it oak for about five minutes. I've learned my lesson. If i go out and smoke em again ill throw some light-adhesive tape on the back ground effects.
Old Jun 3, 2001 | 01:10 PM
Neal's Avatar
Cool
HI!... I use a product called "GOOF OFF". I t literly disolves the rubber instantly. Then I use WD-40 to remove it from the paint and clean up with WINDEX. I had my work cut out for me after that BURNOUT VIDEO I posted in GENERAL DISCUSSIONS last week! It took me about 1 hour to get all the rubber off!LOL! I should of sprayed some "PAM" cooking spray on the rear 1/4's before I did that burnout!LOL!
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings, "WORLDWIDE TRANSMISSION's" RACE 4R70-W tranny with 2000RPM stall converter.
http://members.nbci.com/85merk/movies/Neal_Massive_Burnout-s.mpg
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Jun 3, 2001 | 02:44 PM
CBQB3's Avatar
Post
Any general bug and tar remover will work, with a cotton towel of course.
2000 Silver Lightning
#2798 of 4966
Born on date: May 9, 2000
Email: ColinMBurns@hotmail.com
Mods: SnugLid, 20% tint, Airaid, Slush Mats, Pioneer Speakers, Zaino
My Zing Album:
http://www.zing.com/album/?id=4292665015
Old Jun 4, 2001 | 12:53 AM
Peter B's Avatar
Post
Go to your local Honda motorcycle shop and pick up a can of Pro Honda Spray Cleaner & Polish. It literally dissolves any kind of road grime, tar, rubber, etc, from the paint. It also works great to dissolve bugs front the front end. I used to use it on my street bike and it is to be used on every part of the bike including paint, chrome, plastic, plexiglas, headlights, decals, etc etc. It has never harmed the paint on anything I have used it on.
