Location of the computer?
Old May 31, 2001 | 11:41 AM
seattlesnake's Avatar
Question Location of the computer?
I'm just being lazy here, but I thought someone could give me a heads up on where the computer is at.
Just got my JL Diablo chip and want to install it this weekend.
I'm assuming it's behind the kick panel on the pass side just like the Mustangs are.
Old May 31, 2001 | 11:46 AM
Spike Engineering's Avatar
Post
It's actually located underneath the CD changer. You'll have to remove the passenger seat, the storage box, and some of the electronics for the stereo.
Good luck!
Old May 31, 2001 | 11:50 AM
LIGHTNINROD's Avatar
Post
SPIKE: you dog!
<font face="Verdana, Arial" size="2">Originally posted by Spike Engineering:
Good luck!
</font>
Old May 31, 2001 | 11:54 AM
Lightningquick's Avatar
Talking
Becareful of the cd changer removal.if you do not unhook the battery before you unhook the CD changer,The cd changer will automatically reburn your cds to blank cds.Undernieth is where you will find the computer.its a black box with a big L on it yellow in color.Good luck
Old May 31, 2001 | 11:56 AM
Road Rash's Avatar
Post
Spike
That's a good one. Can you access it by just removing the CD magazine?
Mike
Old May 31, 2001 | 01:36 PM
99svtlightning's Avatar
Post
Installing the chip isn't a weekend job. Just remember to unhook the battery. I swap mine out all the time. The first time should take no more than 15 minutes to clean the terminals well. Once you've done it a few times you can change it in about 3 minutes, including unhooking the battery. It's located on the passenger side under the dash, next to the kickboard.
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
Old May 31, 2001 | 01:46 PM
Post
I just knew I was going to catch a load of huey for asking this.
Thanks 99svtlightning.
The rest of you, I will avoid further questions to at all costs.
Old May 31, 2001 | 01:47 PM
RTKILLA's Avatar
Post
I don't know what you guys are talking about, I took my bed off my truck and then I found it under where the cd changer used to be. Its allot easier that way, Plus you can put the batteries in the custom RTKILLA box. might as well, you got to disconect all the wires that hook up to the battery anyway!
Old May 31, 2001 | 03:38 PM
NeedFourSpeed's Avatar
Post
While you have the computer out; be sure you make the necessary mods to prevent the intercooler from leaking. I changed the clunk washers at the same time.
Old May 31, 2001 | 03:47 PM
Post
Do I need to put her up on jackstands?
Should I drain all fluids before I remove the computer?
And how about the carpet, does that have to come out too?
Come on guys, help me out here.
Arn't those wires behind the truck used for downloading programs onto the CPU?
Old May 31, 2001 | 04:00 PM
Road Rash's Avatar
Cool
check out chucks website lot's of good info
http://home.midsouth.rr.com/lightningpage/
Mike
Old May 31, 2001 | 04:01 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Post
seattle,
the "port" in the back is where Ford prefers to "strap in" their scan tool.
Old May 31, 2001 | 09:19 PM
NOSTROMO
Guest
Posts: n/a
Post
Don't forget the blinker pump changing interval.....must be changed with each unplugging of the computer harness.
Old Jun 1, 2001 | 12:01 AM
Wyldman's Avatar
Post
Spike,
Dude! That's cold blooded!
The
<A HREF="http://www.haloclub.com" TARGET=_blank> </A>
wyldman@houston.rr.com
Black 99.5 Lightning Build # 1273, DOB 5-14-99, NLOC #315
Old Jun 1, 2001 | 12:10 AM
alphadoggy's Avatar
Talking
Whew, that's a relief, I was under the impression that I had to remove my motor to access the computer.
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit, cam bolts, Jackson washers, Wet Okoles, Kenyon transmission
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
gmvye@pacbell.net
