Fuel Pressure Gauge
Old May 27, 2001 | 10:24 PM
Red Chief's Avatar
Unhappy Fuel Pressure Gauge
I just installed a fuel pressure gauge that has a transducer, remote signal box and guage (This is all electrical except for the transducer). What pressure should I expect to read? I think the system has some problems as I am reading 85-90 psi. This has to be wrong. I have checked the wiring several times and everything is wire per the instructions. I plan to call the company Tuesday to ask for some help.
Old May 28, 2001 | 03:41 AM
BlackLight's Avatar
Question
Was that at WOT ?
At what rpm ?
What did you expect to read ?
400 hp/ 8 cylinders = 50 hp of fuel per cylinder, you are going to need some pressure on the injectors.
Old May 28, 2001 | 10:47 AM
Red Chief's Avatar
Post
ttt
Old May 28, 2001 | 11:26 AM
LightningKid's Avatar
Exclamation
These specs are from 2000 repair manual:
Engine running: 28-45 PSI
Key on-engine off: 35-45 PSI
I highly doubt that this spec is differet for '99 or '01. Is there a trim pot of some kind to adjust?
Old May 30, 2001 | 05:08 PM
Spiro99SVT's Avatar
Post
Here ya go from my Mechanical guage, and what I have posted about before in the past.
At idle your looking for 26-28 psi.
At full boost (for me) I am seeing 48 psi.
Hope this helps
Spiro-
12.373 @ 110.15
Best 60' 1.72
@ 4700 w/out the Go-Go juice
11.94 @ 115.31 with 100 shot Go-Go juice @ 4700 lbs.
11.40 @ 113 with 150 shot(on the brakes)NOT BACKED UP!
4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCE
Sales@POWERSURGEPERFORMANCE.NET
