Who is running both upper and lower pullys??
Old May 30, 2001 | 07:37 AM
two fast 4 u's Avatar
Post Who is running both upper and lower pullys??
I would like to know who is running both pullys and if there is any ill efects?? I allready have the lower pully and whant to know if putting the upper would hurt or help. Any one have any ##??
Paul
Old May 30, 2001 | 07:42 AM
99svtlightning's Avatar
Post
I've heard it slows you down because it's hard to get enough fuel. I wouldn't do it, one or the other is enough.
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
Old May 30, 2001 | 09:38 AM
Spiro99SVT's Avatar
Post
Not too sure about a fuel problem with both upper and lower pullies, never heard of that one yet .....but I do know we are blessed with 2 genourous fuel pumps from the factory that should be able to supply all the fuel you need. That is unless your running nitrous (anything over a 100 shot) then a pump upgrade would be a wise move. Luckily we use the same pumps that you find in 87-93 Stangs, so a quick upgrade to twin 190 lph(or larger) will solve ANY problem.
As for both pullies...I have ALWAYS been one one to preach that One pulley is fine, but 2 would not bring any improvement...just more heat. I dont have any numbers to back this up, but I also have NOT seens any improvement in ET's fromt the guys that have added both. So I figure..why add the extra stress for no improvement. IMO of course Hopefully the few that have done will give a reply to this. Hope this helps
Spiro-
12.373 @ 110.15
Best 60' 1.72
@ 4700 w/out the Go-Go juice
11.94 @ 115.31 with 100 shot Go-Go juice @ 4700 lbs.
11.40 @ 113 with 150 shot(on the brakes)NOT BACKED UP!
4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCE
Sales@POWERSURGEPERFORMANCE.NET
Old May 30, 2001 | 04:53 PM
lightning al's Avatar
Post
i really dont understand what you mean, when you are talking about lower pulleys. what do they do and what do they look like?
