Where to get navigator motor???
Old May 23, 2001 | 09:56 AM
RTKILLA's Avatar
Question Where to get navigator motor???
Hey guys, I want to do up a navigator motor with a novi 2000 on it this winter and I was wondering if anybody knows a place to get one cheap. Its going to get new pistons and and rods so I thinking maybe a junkyard if they have a wrecked Navigator. any ideas.
Powered By: POWER SURGE PERFORMANCE Products.
www.powersurgeperformance.net/ubb/cgi-bin/ultimatebb.cgi
Old May 23, 2001 | 10:03 AM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
Post
Killa:
Start here...
http://www.copartfinder.com/
Rich
Old May 23, 2001 | 10:28 AM
RTKILLA's Avatar
Post
Thanks rich!
so it starts!
I found a set of heads for $900 bucks. I wonder if thats a good price on that. do you know where I can find a price on new ones.
Old May 23, 2001 | 03:46 PM
OleSprky's Avatar
Post
If it wasn't for the fact that I would get caught, I could walk next door from the Focus plant to the Michigan Truck Plant and swipe ya a new motor..... shipping would be a bit much though.
Good luck finding the motor though. Is this going to go into the L or some other creation?
2000 White Lightning #808
New Mods as of May 7 2001:
JDM 90mm air intake kit.
JDM Warm Weather Program
Previous Mods:
Pro-M 80mm mass air meter
Superchips R9 chip
Best Stock E/T: 13.92@99.64mph
Best E/T with mods so far:
13.395@101.53mph
Old May 23, 2001 | 03:47 PM
TampaSVT's Avatar
Post
Nope. A link to junkyards was the depth of my knowledge...
Rich
Old May 23, 2001 | 04:35 PM
pvteye's Avatar
Post
http://www.pegasuscustom.com/ford_truck.htm
5.4 32Valve Navigator Engines-New! $3795.00
Rex
RTKILLA's Avatar
Post
KArkraft has them in stock too, brand new.
I want to navigator motor because they have the four walve heads. have those ported and polished and then put some new pistons on the motor and thats all you need. maybe some new bolts but thats about it. Have a intake up top custom made to deliver the most air possible and then blower it with the novi 2000. those blower pump out 25PSI average. thats what I'm talking about, some mean power. JR granatelli is going in the 7's with his 4.6 block and stock crank and stock head ported and polised up. It just seems allot easier then haveing to put a 351 in with all the new wires.
either that or a new 2001 L motor with new pistons, milled and ported and polished heads, and definetly a new blower.
Old May 24, 2001 | 03:14 AM
clonetek's Avatar
Post
dood.. build up a 2000 cobra R motor then strap a novi on it.
brooks
Old May 24, 2001 | 05:29 AM
HIGH RISK's Avatar
Post
RT,
If you are going to do rods and pistons. The cranks are the same in a 5.4 4v and a 5.4 Lightning as are the blocks. So you'll need heads complete with cams. From my understanding the heads are the same as they put on the Cobra. You'll also need Navigator timing chain cover and chain hard ware. (they are different then a Cobra) Coils and harness. If you are going to force feed it the stock intake won't work.
As for a Cobra R motor good luck getting one of those. The heads are different casting with the ports moved around. So even if you could get just the heads it would still be alot of Fab work.
I use to work at the Navigator assembly plant and have done a little figuring. It could be done.
HIGH RISK
Old May 24, 2001 | 07:29 AM
RDY2RAC's Avatar
Smile
j.r. is running a 5.4 navigator motor with custom ground cams not a 4.6 there's a full article of his car in race pages july issue
2000 SILVER L (FOR SUMMER)
95 4X4 FLAIRSIDE(FOR WINTER)
2000 MOUNTAINEER AWD V8 (WIFE'S CAR)
