Vibration Issues
Old May 20, 2001 | 10:49 PM
NOSTROMO
Guest
Posts: n/a
Post Vibration Issues
Got an 01 with vibration issues...I cant tell if it is the tires or the driveline or maybe even the exhaust as some of you mentioned before.
It happens between 70 to 90 mph. at 90mph i throw the tranny in neutral and let the truck coast. Shifting into neutral at this speed doesnt seem to make any difference.
Anyone else with similar issues?
Old May 21, 2001 | 04:53 AM
Fast Gator's Avatar
Post
I noticed a slight vibration in mine on the NJ Turnpike one morning after a 75 to 135 passing move. I figure its because of the gears, compared to the 3.55's that I was used too. I don't think it's much of a big deal, only time will tell.
1999 Black Lightning... 1940 of 4000... Traded for: 2001 Silver Bolt... Adopted 3/24/01... Red Line Water Wetter... Wet Okole's... Bed Rug... JL Stage II Ram air... Chipless in Jersey
Old May 21, 2001 | 01:09 PM
36racin's Avatar
Cool
SOUNDS LIKE YOU BOTH ARE HAVING THE ALUMINUM DRIVE SHAFT OUT OF BALANCE PROBLEM THAT THE EARLIER YEAR TRUCKS ARE HAVING.
Old May 22, 2001 | 08:47 PM
NOSTROMO
Guest
Posts: n/a
Post
I called the dealer....and he tells me i shouldnt be driving at 90mph anyway!
I mean as soon as you have a problem it's like they find every which way to turn you away....I thought being an SVT dealer meant something?
Anyway, a little update
I just purchased the exhaust dampeners and I am going to speed balance my tires and make sure the runout on the wheels are within specs
However the driveshaft .....i would have to send that out to get the balance checked on it....I could try rotating it 180 degrees and see if that helps.
Old May 22, 2001 | 09:21 PM
Mondo1's Avatar
Post
2 words...Exhaust equilization. Do a search for this. Very common with all L,s.Many posts about it.
Old May 22, 2001 | 09:30 PM
NOSTROMO
Guest
Posts: n/a
Post
I did do a search..hence the pipe dampeners i just ordered!
Hey silver....even though you cannot feel the vibration at lower speeds...its still there and chewing away at your pinion bearings, tranny tailshaft bushing, and u-joints.
Old May 22, 2001 | 10:01 PM
Don C's Avatar
Post
here are two threads that might help you out
https://www.f150online.com/f150board...ML/010204.html
https://www.f150online.com/f150board...ML/011006.html
DON'S ZR1 KILLER
SILVER 2001 LIGHTNING
Sportmasters tonneau
Bedrug
Alpine head unit and six disk changer.
JL Audio speakers
Magnaflow muffler
JDM BigMouth Filter.
13.248 @ 104.61
http://donf150.tripod.com/Welcome/id6.html
http://www.zing.com/album/?id=4294607313
Old May 22, 2001 | 10:14 PM
SVTDAVE's Avatar
Cool
Hey Anthony are you sure its not all that dirt on your truck causing the vibrations??
Dave
'01 White
Alpine CDA-7875
MB Quarz
Rockford Fosgate Punch
JL ramair (ordered)
Level 10 (ordered)
Old May 22, 2001 | 10:32 PM
NOSTROMO
Guest
Posts: n/a
Post
hey Don C thanks.....it was you that informed me about the dampner. I ordered two of em...49 dollars each. Did you have similar symptoms Don?
SVTDAVE - you might have a point there...i still havent washed it....but i will though.
Lightning dirty = owner bad
Lightning clean = owner good
