42lb injector details???
Thanks again for all your help.
I did some searching through the Lightning forum and found that yes, they do use a vac/manifold ref'd fpr.
As for screenshots....can you open the respective injector tables in your tuning software and do 'shift+printscreen' then go to 'Paint' and do a 'cntrl+V'.
It shopuld copy the displayed screen. Then save it and either post it here or email it to me at hquick@bigpond.com
That'd be fantastic if you could.
Thanks again
Howard
Thanks again
Howard
Hey 'lightningtuner' (Sal?).
Marcin (redhardsupra) is working on a spreadsheet to convert details from the ford tune injector values to a GM based tune.
There's alot of us using the 30, 36, 42's and can't find any/all needed info.
Seeing the stock settings from a lightning with the 42's as stock OEM might help.
Any info/help/material you can offer would be greatly appreciated.
Howard
Howard
