Power Steering unit
Old May 17, 2001 | 05:19 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Question Power Steering unit
I took my truck in today to the dealer and they could not find the problem with the noisy power steering unit. They said they only hear it when they are inside the cab and hear nothing when outside. They went on line (is whet they told me) to find out from ford what it could be. After 3 hours they replaced the power steering unit and low and behold the noise remains.?? Now i have an appointment for them to change the gear box???. could this be the problem, its under warrenty (by 3 days). The unit growls when the wheel is turned either way and the idle seems to lower to much also. Sorry for the long post but this seems like it should be a no brainer but NOTTTT
1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Old May 17, 2001 | 06:21 PM
Exclamation
One other thing this dealer just got there blue oval cert. Just what does the blue oval cert. mean?
Old May 17, 2001 | 06:31 PM
Rzk's Avatar
Rzk
Post
My 01 Bolt makes the same noise. Left turn, Grrrr..... Right turn, Grrrr.... Do a search on power steering noise. I think loud power steering noise is normal to F-150's in general.
Old May 17, 2001 | 06:33 PM
Ivanhoe_Farms's Avatar
Post
I have a 2000 with 650 miles on it, and it is has the power steering noise. It does not sound like the pump, it sounds more like it is coming from the steering box itself. The noise is not very loud and I only notice it when I turn the wheel when I am not moving.
It is more like an air sound in the steering box as opposed to the whine one hears from the power steering pump -- it will be going in soon.
Old May 17, 2001 | 06:37 PM
zeroxman1's Avatar
Post
For as long as I can remember with all the Fords (and Lincolns) my family has owned including my own 2 vehicles, they have always made a groaning sound when you turn the wheels and also make the idle dip a bit too. I don't know if there is something wrong with yours but here is what I did when I got my truck: Started it up, (thought to myself---wonder if Ford made the P/S noise go away yet?) NOPE!!!
Steve
Mine:
1999 F-150 Sport Supercab
Bright Red 4.6L Auto
Billet Grill, Billet Ant, Clear Corners, Sony CD Player, Pioneers in all doors, Kicker 100si Amp, MTX preformed underseat box. Fiberglass Bed Cover
Hers:
2000 Expy Sport
Black, Grey Leather 5.4L
Clear Corners, Alpine CD Player, Punch 150 Amp, JL Audio preformed sub box in rear panel.
Old May 17, 2001 | 07:01 PM
Post
I have an appointment on the 29th and they will replace the gear box. I will update what they did and how it turns out then. Thanks to all of you this site continues to be a great source.
Old May 17, 2001 | 08:24 PM
Silver-Bolt's Avatar
Post
Mine makes the same noise. So did my 99 F350 and 97 F150. Someone told me it had something to do with the hydralics lines. Something about the pressurized fluid passing over a textured surface inside the hoses.
2000 Silver Lightning 13.16 (so far)
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
F-250 Trans pan
MagnaFlow 12468
Snug-Lid
I feel a 12.xx coming on.
Team PSP West
Old May 17, 2001 | 08:32 PM
RedThunder's Avatar
Post
My 99 Lightning is dead silent from the p/s.
I did have to change the pitman shaft seal myself, as it was leaking.
For $10 in parts and a half hour labor it wasn't worth it to go back to the dealer.
Even after bleeding all the air out, it's still quiet.
Old May 17, 2001 | 08:33 PM
gforce's Avatar
Red face
Oh jeez, I wish I hadn't read this post..something else to go wrong. Mine is dead silent clear to the stops even though it has a mind of it's own on worn roads and wanders horribly.
Old May 17, 2001 | 09:24 PM
Post
gforce don't worry i have yet to drive a truck that did not wander some on rough and worn side roads. You could try some adjustable high per. shocks. This would help.
Better 1/2 : 92 Red T-Bird.
Old May 17, 2001 | 09:35 PM
NOSTROMO
Guest
Posts: n/a
Post
Could this be the classic NYAAA NYAAAA whine?
Old May 17, 2001 | 09:44 PM
Post
NOSTROMO
could be could be i know lets all ask RJ
Old May 18, 2001 | 07:17 PM
Angry
+Got up this morning and started up the truck now i am getting a squeeling (while cold) from under the hood after they had just installed the new power steering unit yesterday??. It didn't squeel before they touched it but it does now. May god have mercy on there souls!!!!!!!!!!!!!!!!!!!!!!
Old May 19, 2001 | 09:53 AM
WhiteLightning99's Avatar
Post
My 99 makes the power steering noise, its kinda like a screching, its made the noise since I've had it, and now it has 33,000 miles. It doesnt really bother me if anything its annoying.
