Attn. Pro-Sport bed lid owners
Old May 18, 2001 | 06:31 PM
Undy's Avatar
Thumbs up Attn. Pro-Sport bed lid owners
As several of you I've experienced some rubbing on the bed from the Pro-Sport lid. In fact it rubbed clean through the base and clear coats. My rubbing occured on the right rear outside corner about 5 inches up from the rear. I called Innovation and talked to one of the installation techs. He told me to adjust the hydraulic lifts or shave the fiberglass. I tried the lift adjustment to no avail. I was looking carefully at the right rear corner and discovered something. I found the the fiberglass sort of dropped down or was lower on the right rear, outside corner about 1/8" lower than the rest of the bed. I got a block sander and took about 1/8" off the bottom there. I then peeled back the carpet inside and shaved the inside of the lip. I then reglued the carpet back down and touched up the bottom of the lip with the paint Innovation provided. Now there's no rub and it even looks better, more uniform.
I don't know if this is related to any of your rubbing problems but I've a sneaky suspicion it is.
2001L, red, born 2/6 and arrived 2/28!!!
JDM chip
12" Big Mouth filter
Wet Okoles
Bedrug
Pro-Sport Lid
Let the mods begin....
1969 Vette coupe, 496ci stroker big block, aluminum heads, 4340 crank & H-beam rods, JE 10.8 pistons, roller everything, McLeod dual disk clutch w/ aluminum flywheel, Richmond 6 spd, 3" dual exhaust, 300hp nitrous fogger, much, much more.
LS1 eater.. big time!!
1985 FoToLet, work truck, 85 Toyota 4x4 (started as), Reading bed, ladder racks, 8" lift, 33 x 12.5's, Vette 350 4 bolt motor, Hooker Super Comp headers, Ford 9" rear, Toyota front diff, turbo 350 coupled to a Toyota transfer case, 410 gears, a/c & power steering. f-a-a-s-t A/C & heat calls..... my specialty.
web page: http://personal.picusnet.com/undy
Old May 19, 2001 | 01:41 AM
Speedracer29's Avatar
Post
I had the exact same problem. I just took some felt and put it on the insides around the area's that were rubbing. It tool care of the problem
Jason Hogan #29
www.JasonHogan.com
My Zing Album New Pics Added 4-25-01 (Lightning pics added)
-2001 Silver L (Recived 3-13-01)
Best ET: 13.57 @ 101.13mph
mods,
Dual Borla Mufflers,
Beltech 2inch drop Shackles
Pro-Sport bed cover
Ram air hood
BedRug
window tinting
SuperChip
SVO Throttle Body
Phazer II Radar Jammer
Clarion Head, TV Unit, and DVD Unit
Custom Box with 2 Kicker 12inch Comp VR Subs
Old May 19, 2001 | 03:52 AM
GalaxyEng's Avatar
Post
I sanded mine as well, you would think they would test fit them when they make the mold
GalaxyEng
2000 RED #2926
13.2@104
BedRug
Haig custom mats
PSP Filter
PSP 4-way
Pro-Sport Tonneau
Old May 19, 2001 | 07:29 AM
keeft's Avatar
Post
With mine it started to touch at the right rear after a couple of days once the rubber weather seal compressed under the weight of the lid. I actually added some extra rubber weather seal (stick-on from Home Depot) that filled the channel between the lips of the original seal and lifted the lid about 1/16 inch. I also took out my Dremel and ground down the edge so it matched the clearance on the left side.
2001 Silver frost built on 2/27, delivered 3/16
Pro-sport, Airaid JDM chip
1996 Ram 4x4, 360ci, lifted, Mopar chip, JBL headers, dual 2.5"
1999 E.B Expedition
1968 Dodge Coronet 500, 383ci with six-pack
