digital odometer?
Old May 17, 2001 | 02:31 PM
LIGHTNINROD's Avatar
Post digital odometer?
i didn't see any explanation in my owner's manual...can anyone tell me, does it do any more than show total miles? unless i'm missing something(very possible); there is no "trip odometer" function, right?
2001 Lightning, silver, bot/picked up on 05/08/01, 1997 f150 xlt 4.6L 4x2 with: a/f one fipk, superchip, optima battery, bbk 75mm throttle body, edelbrock ias shocks--2001 lightning to come(she came--see above)
Old May 17, 2001 | 02:39 PM
Blown5.4's Avatar
Post
Yes, you can switch between trip and odometer by pressing the plastic post next to the odometer. Hold it in for a couple of seconds to reset the trip meter.
If you hold the button in, while starting your truck, the odometer will display diagnostics (computer codes, oil temp, speed, tach...)
DB's Avatar
DB
Red face
Just a push of the button between total vehicle miles and trip miles...
[This message has been edited by DB (edited 05-17-2001).]
FASTRK99's Avatar
Post
Push in on the little **** and hold it there. It will switch over to "Trip Odometer" Do the same thing to erase.
There is evidently a way to get engine codes from it also but there is a sequence I don't remember that was posted here.
Old May 17, 2001 | 02:43 PM
FASTRK99's Avatar
Post
Old May 17, 2001 | 02:51 PM
CornerCarver's Avatar
Post
Press and hold button with key in "off" positsion. Turn key to "on" while still holding button down. After about three seconds you will see "test" come up. Release button and press to scroll thru. Trun the key to "start" and you will have real digital readouts on fuel, battery voltage, speed, tach, engine temp., etc. etc.
Paul
'01 Silver L
Moderator: FASTasL at EFI-Street.com
Old May 17, 2001 | 05:06 PM
BlackLight's Avatar
Question
<font face="Verdana, Arial" size="2">Originally posted by CornerCarver:
... and you will have real digital readouts on fuel, battery voltage, speed, tach, engine temp., etc. etc.
</font>
How about oil pressure...
Old May 17, 2001 | 05:34 PM
Post
If I remember correctly, it just gives a reading saying that there is pressure. Pressure isn't given, just that there is oil pressure.
The '99 Cobra that I had, the oil gauge was an idiot gauge. As long as ther was more than 5psi of pressure a pressure switch was made and the gauge went to the center position. I would almost bet it's the same on these trucks.
Old May 17, 2001 | 06:41 PM
4D THNDR's Avatar
Lightbulb
Right CornerCarver, since '86 if I remember correctly 4 PSI initiates it.
Red '00 Lightning,
Power Surge Performance enhanced,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
Old May 18, 2001 | 12:10 AM
BfB's Avatar
BfB
Banned For Rules Violations
Post
Unfortunately this method doesn't work while driving, correct? Well, I guess it does, but I'm wondering if you have to reset this everytime?
BfB
[This message has been edited by BfB (edited 05-18-2001).]
Old May 18, 2001 | 01:41 AM
bambino's Avatar
Post
It does work while driving, i've had it up for a few of the different displays.
It will not be there when you start it up again, you'll have to initiate it again. And, it will erase your trip odo in the process.
Bambino
Bambino Worldwide
Owners Gallery Truck #179
1999 reg cab/short box/ORP/Silver on Dk Graphite - 3.55; 4.6l 5sp; Factory Tonneau; Kicker amp'd sub tubes; Rockford Fosgate components up front; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820s; Amsoil Series 2k in the driveline.
Old May 18, 2001 | 02:14 AM
HIGH RISK's Avatar
Post
Do a search on this. There is a link to a Mustang Chat room that goes over in detail all the functions of the LED read out that is the odometer. IE, Digital tach., Oil press., Temp., Fault Codes and alot of other things.
HIGH RISK
