Hey Don C......
Old May 15, 2001 | 06:46 AM
WHAT04's Avatar
Question Hey Don C......
When you got your exhaust system worked on, did they cut the hanger that attaches the driver's side pipe to the transmission?
Curious because I am still having some nagging issues with my truck.
Thanks!
2001 Red Lightning Delivered 3-15-2001, 2" Aim Lowering Shackles, Hitch Removed, Group Purchase Floor Mats, Modified Light Switch for Fogs, JDM Filter Kit, Single-Bladed T/B, Keyless Entry, Magnaflow 14568, 22% Tint, Chrome '00 Rims, Bed Rug, M Pulse Lo-Pro Tonneau, Other Goodies. Best Time: 13.41 @ 104.37 mph
2000 Red Lightning - #835 of 4966 Sold 3-8-2001
2001 Yukon Denali White, All Stock
My Zing.com Album Click Here
Old May 15, 2001 | 06:56 AM
Don C's Avatar
Post
Good morning
No my hanger that goes to the transmission is still hooked up.
I hope you figure out your problems, but I don't know what to tell you seems like you have done all the right things so far.
Did you check the tires real good?
Old May 15, 2001 | 09:27 AM
WHAT04's Avatar
Post
Thanks for the quick reply Don. My muffler install now has the following: tranny hanger removed (done by dealership before delivery) and the connector between the two inlet pipes to the muffler disconnected (pipes were moved further apart, as you know).
I have a vibration between 60 and 75 mph, not earth shattering, but still a bother. The real problem is that this vibration is not consistant. Sometimes it's not even evident.
I had my chrome '00 wheels installed last week and nothing has changed. Possibly in the driveline ( but the inconsistancy sort of negates that) or it's in the exhaust or engine. My guess is the exhaust.
Any other guesses are most welcome!!
Old May 16, 2001 | 09:27 PM
Don C's Avatar
Post
Hey What04
I have been thinking about this for a day or so.
The place that installed my muffler, has it so there is a lot less movement than when it was stock.
Maybee by reducing how much the exhaust can move might solve your problem. You might want to try temporarally installing a extra bracket or two and see if that helps.
Old May 16, 2001 | 10:14 PM
WHAT04's Avatar
Post
That is the plan Stan. I have some high-polished BABolt tips enroute and will tighten the system during the install.
I also wonder whether I may have a bad coil. Don't know how to check this without a service call. Will pull some plugs soon.
Thanks for the interest.
