Deep Tranny Pan
Guest
Posts: n/a
Anyone know of a deeper transmission pan for the 4R100? Is the 4x4 pan deeper or are people using it cause of the plug? Will the E4OD pan fit....B+M makes a deeper pan for the E4OD and was wondering if the bolt pattern is the same.
The 4x4 pan is a little deeper. Maybe an extra quart. Drain plug is the big advantage. Cheap too.
2000 Silver Lightning 13.16 (so far)
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
F-250 Trans pan
MagnaFlow 12468
Snug-Lid
I feel a 12.xx coming on.
Team PSP West
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
F-250 Trans pan
MagnaFlow 12468
Snug-Lid
Team PSP West
The E40D will work. The bolt pattern is the same. You will get 3-4 quarts more fluid plus have a drain plug. The pan is also finned on the bottom..
99.5 Lightning
Gone but not forgotten
01 picked up on 5/5/01
hud@mc.net
99.5 Lightning
hud@mc.net
<font face="Verdana, Arial" size="2">Originally posted by NOSTROMO:
Jeff are you reffering to the B+M E4OD tranny pan?</font>
99.5 Lightning
hud@mc.net
Contact Harvey at www.performanceautomatic.com . I purchased a ALUMINUM pan frm them, it was manufactured by HUGHES. The pan is ribbed,4.5 qts larger than stock,cast aluminum,has a drain plug, complete with filter, hardware, gasket.
I dont recall the price, but I know about 20-25 L owners here took advantage of it when I first posted about it. Check it out..
Spiro-
12.373 @ 110.15
Best 60' 1.72
@ 4700 w/out the Go-Go juice
11.94 @ 115.31 with the Go-Go juice @ 4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCE Title Sponsor WFC4
Sales@POWERSURGEPERFORMANCE.NET
Spiro-
12.373 @ 110.15
Best 60' 1.72
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
<font face="Verdana, Arial" size="2">The pan is ribbed</font>
Rick
SVT Performance
Moderator 2nd Gen Lightnings
White 00 #2236 of 4966
My Mods & Web Page
<A HREF="http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/p0903ca5788ed2e743923d60b1a060fed/feb8b2de.jpg" TARGET=_blank>
</A>
Stick with the stock convertor for now...it works just fine for me
As for the shift-kit, yes..now would be the time for that. Let me know if I could be of help
Dont forget a case of MERCON-DEXRON III
The"GREEK"
The"GREEK"
I am running the Level 10 and like it. Pretty firm shift with the big valves and springs, but I like that.
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
F-250 Trans pan
MagnaFlow 12468
Snug-Lid
Team PSP West
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
F-250 Trans pan
MagnaFlow 12468
Snug-Lid
Team PSP West
Hello;
Yes we are machining the proto type 12-9.75 rear end fend cover casting and should have the production done by May. We have the Ford 4R100/E4OD trans pan $325.00@ holds 8 qts more oil and cools up to 30 degs.
Roy @ Mag-Hytec "quote from Roy@Mag-Hytec"
hope I don't get busted...I am not the vendor
8 more quart capacity..and they have the rear diffy cover...
