Paging BOLT
Old May 10, 2001 | 01:25 AM
DJY's Avatar
DJY
Question Paging BOLT
Hi Bolt I have a question for you. I just ordered A Heavy Duty C-Section kit from Western Chassis. I was wondering did you take off your bed to install the C-Sections??? What did you use to cut the Frame??? My friend has a Plasma Cutter did you use a Plasma Cutter to cut your frame??? I just cannot handle my Lightning always bottoming out while driving with the Bell Tech 3/4 kit and Western Chassis 2 inch A-arms.
Thank you in Advance, DJY
Old May 10, 2001 | 11:15 AM
Bolt's Avatar
Talking
DJY,
I did not have to remove the bed. The frame is pretty soft material so a Sawzall with a metal cutting blade works well. On the driver's side you will have to contend with the gas tank if you use heat. Also take a look above the 3rd member and around the middle of your drive shaft. You might want to modify these points. Send me an e-mail if you want to talk live.
Airaid, Spal Fan, FPPTB,PSP Pulley, Brembo's, R9 Flip Chip, PSP loop, 4:10's.
Old May 10, 2001 | 10:41 PM
DJY's Avatar
DJY
Post
Bolt, Thank you for the advice. My friend who is going to help me has a Sawzall too! It might be safer using the Sawzall. I'll update you when I finish. I'll check the third member too! DJY
Old May 11, 2001 | 02:05 AM
Bolt's Avatar
Post
DJY, make a cardboard template that matches the inside of the c-section, scribe it into the frame so you know exactly where and how much to cut.
Old May 11, 2001 | 02:17 AM
DJY's Avatar
DJY
Post
Bolt, Got my C-Section Plates arrived today from Sport Truck Direct they sent me the C-section plates but forgot to send the hardware - bolts, washers, nuts,and new bump stops, template and instructions. Am I just cutting out the section where the hole is in the middle of the C-section plate, where the axle goes thru and bolting the plate to my frame??? Good idea you suggested in case there is no template. I'll probably install next weekend when I have all the hardware sent to me in Hawaii. I'll keep you posted. Thank you, DJY
Old May 12, 2001 | 11:38 PM
Bolt's Avatar
Post
"Am I just cutting out the section where the hole is in the middle of the C-section plate, where the axle goes thru and bolting the plate to my frame???"
Yes... only take out material in the middle.
The C-section bolts all around where you will make the cut, side and bottom. Have a large "C" type clamp to hold it in place when you mark your holes. I found that it worked best when I drilled a small pilot hole and used a 1/2" Unibit. You might want to relocate the driver side emergency brake cable to under the spring.
Old May 14, 2001 | 04:56 PM
alphadoggy's Avatar
Question
David, what the heck are you doing to your truck now? I'll be in Haleiwa on the 25th, 26th, and 27th. My kid and I would kind of like to scope out your ride. Can you give me your phone #, if you don't mind?
