Abaco Performance 97MM MAF
As you all know, I just installed the 3.4L Whipple recently. I was talking to Bob during the install and looking at my intake set-up, and it seems that the stock 90MM MAF that I'm using is a restriction right now. Plus, at the higher boost levels the stock MAF, even extended, may prove to not be enough. I was flipping through MMFF and came across an advertisement for Abaco Performance Digital 97MM MAF's. I was wondering if anyone had heard anything about them or has an opinion on this subject???
http://www.abacoperformance.com/
I talked with them for quite a while at PRI, it looks to be a damn good product, but I don't have any personal experience with it yet, as the cost is quite high vs. using the stock MAF with a MAF.ia. most people tend to go that way.
i haven't heard of the pricing being set yet. but honestly i look into PMAS Professional Mass Air Systems. i am running one of there Velocity's on my Paxton setup and its curved for 3500 kg/hr i've seen 32 psi and it still only saw like 4.3volts not sure on the maf counts but once i get my trans back together we'll be hitting the dyno for some more tuning.
or better yet go with the PMAS HPX slot style sensor in a 5 inch tube and have all the range you will ever need. and it'll still be about half the price of the abaco.
