Calling Sal
Old May 13, 2001 | 01:36 AM
reality1's Avatar
Post Calling Sal
Sal,
the new Cal Tracs don't fit with the Bassani
Tried to call but I guess you were at the Dyno
The Spring Stop Bolt is 1 inch above the spring and forward pivot assembly is tight against exhaust. Please give me a call.
Old May 13, 2001 | 08:57 AM
BigD's Avatar
Unhappy
Jim,
The answer is....take the Bassani's off...easy answer I'm sure Nancy won't mind
...Dwight...
Old May 13, 2001 | 11:04 AM
LightningTuner's Avatar
Post
Jim, it sounds like your Bassani is not fully seated. There is a lot of room on the slip fit parts of the pipes, before and after the "X" section. I had to redo mine about 4 times when I first put the exhaust on so it wouldn't leak. I thought that it was on good, but it still had about an inch to go. If your Bassani sits that far back, it sound like the pipes need to be seated farther onto the "X" section. Hope this helps.
SAL - TEAM PSP
web- www.powersurgeperformance.net
E-mail sales@powersurgeperformance.net
tech@powersurgeperformance.net
F-150 Online Supporting Vendor
