How to check for piston preasure with diablo tuner?
Old Mar 17, 2008 | 01:43 AM
ace1_123's Avatar
Im running stock 02 L. Does anyone know how to use the diablo tuner diagnosis program to check cylinder preasure? and what should the preasure be? PLEASE HELP!
Old Mar 17, 2008 | 06:55 AM
torkum's Avatar
Don't think any scanner can read cylinder pressure simply because there is no sensor on the engine to give the ECM that type of info.
Old Mar 17, 2008 | 10:19 AM
Robert Francis's Avatar
As noted above: there is no "device" on these engines to read cylinder pressure.
Old Mar 17, 2008 | 10:34 AM
pitstain's Avatar
You will need a cylinder compression/leakdown tester, but you already knew that......???
Originally Posted by ace1_123
Ive been working on stangs for 5 years now. Im new to lightnings but not to cars in general. ........
...but i have a couple of family members that are ford and lincoln mechanics and they have told me .........
Old Mar 17, 2008 | 12:42 PM
ace1_123's Avatar
Oh okay. Im new to the 5.4 block. Sorry guys 5.0 olds are my thing. Was just wondering if these (newer) blocks had some sort of compression sensor.
Old Mar 18, 2008 | 07:16 AM
Dbl G's Avatar
Ummm, Nope.
Old Mar 18, 2008 | 12:37 PM
B-Man's Avatar
What ????
Are you insinuating that a 5.0 has a sensor for cylinder pressures ?
Old Mar 18, 2008 | 02:51 PM
Struck in AZ's Avatar
You mean yours didn't???
Old Mar 18, 2008 | 08:53 PM
Ct.TOPGUN's Avatar
How else would you know where to set the compression ratio dial?
Old Mar 18, 2008 | 10:33 PM
ace1_123's Avatar
NOOOOOOOOOOOOOOOOOOOOO
what i meant was that (ofcourse i know 5.0 does not have sensor) i was just asking maybe the 5.4 did? Sorry for the confusion guys.
Old Mar 18, 2008 | 10:47 PM
built54's Avatar
They know that... this is how they are! it all has to be manually tested. peak pressure isnt really what you are looking for, consistency is what you want.
Old Mar 19, 2008 | 02:39 AM
ace1_123's Avatar
Coo Thanks
Old Mar 19, 2008 | 04:21 AM
birdy111's Avatar
no flux capacitor comments gang? what is f150 coming to...
Old Mar 19, 2008 | 09:58 PM
bnehila's Avatar
If you have access to a Ford IDS (scan tool), you can do a relative compression test with it. It doesnt give you pressures but a scale to show consistency in all cylinders. It measures rpm differences with the ckp sensor.
Old Mar 19, 2008 | 11:25 PM
joshmac4.6's Avatar
Yea def. the easiest and least intrusive way. The only problem is that if all the cylinders are equally worn, and they are all low then the IDS cannot pick this up. You should see from 185 -205ish for the cranking rpm while the test is done on a V8.
