Nasty little problem
Done some work on the L this week, It's a 99 and had the leaky intercooler#core so fitted the replacement 10 row one. While it
was in bits changed the plugs to TR6's put on 6lb pulley, 90mm Maf,
and filter. Uploaded an LFP tune that came with the kit on an XCal 2
but when I ran it the truck did not want to go above 3500rpm, felt
like it was breaking down. If I built up revs slowly it was fine just didn't
like sudden acceleration. DTC code thrown up is P0107 MAP Cir low.
Could I have disturbed something replacing the core ? All looks to be
as it should be but it is the first time I have done any work on the L so
may have done something wrong I guess
Any ideas on what
to check greatly appreciated.
Col
Any ideas on whatto check greatly appreciated.
Col
Been over the connections again and again and everthing seems to be
firmly in place be it vac pipes or electrical connections. Waiting for another
tune to be sent in the mail then take it from there.
If you can get down to my place this weekend I could go through the motor with you and see if we can sort it out.
Ricki
Ricki
Ricki
Ricki
be back bigger and better for later in the season ?
Thanks, Col
