e-brake light keeps coming on
Old Mar 13, 2008 | 09:11 AM
trucknut1378's Avatar
for the past couple days the e-brake light has been coming on. it will come on and then go off randomly. no the e-brake is not engaged. is this a common problem? how can i fix it?
Old Mar 13, 2008 | 09:16 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
I think that light has double duty.
It tells you when the parking brake is engaged.
It also indicates a brake problem.
The random illumination may mean your brake fluid is marginally low.
Old Mar 13, 2008 | 11:20 AM
never thought about that thanks. i'm goin to check it now
Old Mar 13, 2008 | 02:04 PM
oldfrmtrk's Avatar
You might want to look at the micro-switch that detects the location of the arm, it might be malfunctioning, or out of aliment (loose).
Old Mar 13, 2008 | 04:01 PM
halcyon's Avatar
where is the micro switch? my e-brake light blinks on startup, so i know its not burned out, but it never lights when i engage the e-brake for parking???
Old Mar 13, 2008 | 04:09 PM
pitstain's Avatar
I had the same issue, it was low brake fluid.
Old Mar 13, 2008 | 05:39 PM
oldfrmtrk's Avatar
It’s a good thing I’m not a mechanic, or make my living as a mechanic!!!!!
How do’s the system detect that the e-brake pedal has been depress, and activate the light????
Old Mar 14, 2008 | 07:29 AM
when the pedal is not depressed it makes a ground. but when it is pushed down its an open and the lil bit of power runs through the bulb and it lights it up.
Old Mar 14, 2008 | 11:34 AM
oldfrmtrk's Avatar
Well in that case, I’m sure that we all know that once their is a ground, you will always have a ground!!!!
Their is no possible way that corrosion would build up and create a non-ground action while driving the vehicle…. (Thereby flashing the light!!)
Like I said, good thing I don’t make a living fixing trucks!
And by the way was the fluid low??
Old Mar 14, 2008 | 11:53 PM
it was about half. i havent gone anywhere to get some fluid and fill it up so i will update after i fill up the resivor.
