hey 99SVT Lightning
Old May 3, 2001 | 12:17 AM
14U2C's Avatar
Post hey 99SVT Lightning
Thanks for your reply. I did what you said. I didn't see the little whole in the rubber. I put the sensor in there but the light is still on? I turned it around in the whole and nothing? I can't figure it out?
Old May 3, 2001 | 12:35 AM
blue blood's Avatar
Arrow
Disconnect the battery, turn your light switch on (to drain the memory in the computer) then reconnect.
Tom
Old May 3, 2001 | 09:05 AM
99svtlightning's Avatar
Post
The light will go off now if you disconnect the battery like blueblood stated. Looks like your in business now. Good luck, be safe, and have fun!
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
