Help! JL Air Kit (service light)
Old May 2, 2001 | 07:25 PM
14U2C's Avatar
Question Help! JL Air Kit (service light)
Installed my JL Airkit and now my service light is on. I plugged the metering block sensor back in. I assume the airbox sensor is suppose to be exposed? Does anyone else have this problem? Thanks for any help.
01' White Lightning
Old May 2, 2001 | 09:04 PM
99svtlightning's Avatar
Post
The JL Air Kit shouldn't make your check engine light come on if you hooked everything back up. Make sure you plugged your MAF sensor in tight and your AIT sensor all the way into the rubber grommet. It should be turned so that air can go through the little hole and hit the sensor. Post a reply if everything checks out OK.
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
