Weight Reduction 101....part 2
Everyone,
I have had a couple more days to do some testing and verified the weight of some more items:
Stock Pulley (On Cage) 11 lbs
Trailer Hitch assembly 47 lbs
Factory jack (Under passenger seat) 7 lbs
I figure I can cut out 150 lbs between some simple remove (Not the pro-sport) and using 16" wheels......
Should help the old times tomarrow......
Side Note: After taking the factory pulley off and seeing/feeling its weight, I think its obvious why it has the support cage. I have never seen a pulley on any auto applications I've dealt with weight this much. If you let the raw 11 lbs hang on the end of the crank, for sure you would have problems.
Later
Brian K
99 black L
13.24 @ 103.51
tomarrows diet plan times TBD
Later
Brian K
99 black L
13.24 @ 103.51
Let me hear you ran a 12 Brian.. GOOD LUCK!!
you have mail
Spiro-
12.373 @ 110.15
Best 60' 1.76
@ 4700 without the Go-Go juice
11.94 @ 115.31 with the Go-Go juice @ 4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored byPOWER SURGE PERFORMANCE
you have mail
Spiro-
12.373 @ 110.15
Best 60' 1.76
-Stock Meter
-Stock TB
-Stock Heads
-Stock motor
How much does the stock battery weigh? A Optima battery weighs 38 lbs. Also if you drain the widshield washer fluid you can loose 6-7 lbs. The winshield wipers don't weigh much but would make the truck a little more aerodynamic if you removed them.
Also If tou put a electric fan on you would loose about 10lbs of rotating weight. That alone will reduce your et's
SILVER 2001 LIGHTNING
Built 02/14/01
Picked up 03/03/01
Sportmasters tonneau
Bedrug
Alpine head unit and six disk changer.
JL Audio speakers
Magnaflow muffler
JDM BigMouth Filter.
http://donf150.tripod.com/Welcome/id6.html
http://www.zing.com/album/?id=4294607313
Built 02/14/01
Picked up 03/03/01
Bedrug
JL Audio speakers
Magnaflow muffler
I just took the pass seat out and I don't think it's 100lbs. Felt like 50 or 60lbs, which still helps.
Rick
SVT Performance
Moderator 2nd Gen Lightnings
White 00 #2236 of 4966
My Mods & Web Page
<A HREF="http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/p0903ca5788ed2e743923d60b1a060fed/feb8b2de.jpg" TARGET=_blank>
</A>
Rick
SVT Performance
My Mods & Web Page
</A>
I don't know about you guys, but for me my biggest weight saver would be my girlfriend!!!
105lbs.(i didn't say that)...
I can't keep her out of my truck
TRUCK
White 00' XLT 4.2 Auto Sport
Regular cab Styleside
3.55 non-limited slip
Superchip
Airaid FIPK
custom ported STOCK throttle body
1/4 ... 17.221@81.35MPH
PC
Thunderbird 1.1ghz @ 1.33ghz
Abit KT7A-Raid
384mb Kingmax PC-150 ram
60gig IBM 75gxp RAID array
Geforce2 GTS 64mb
TRUCK
Superchip
Airaid FIPK
PC
Abit KT7A-Raid
Geforce2 GTS 64mb
