Zex Kit on a Stock 2000
Old Feb 20, 2008 | 01:24 PM
blazen5.4's Avatar
Question Zex Kit on a Stock 2000
Well i installed myZex kit with purge an bottle warmer . I have right around a 60 shot using nx pills that work with this kit . Whats the highest i can go before i need to get a maf and a tune? I have a cold air kitand exhaust but maf is stock. Thanks !! I have tested the 60 and runs good ,i want more..
Old Feb 20, 2008 | 01:41 PM
my98stang46's Avatar
ditch the nitrous, go with the usual mods and youll like it more.
Old Feb 20, 2008 | 02:22 PM
blazen5.4's Avatar
Thumbs up Bumped it
Well i just tested a 76 shot ,it is night and day!!! I will be taking to the dyno to assure every things were it needs too be.
Old Feb 26, 2008 | 06:19 PM
lightningkylej's Avatar
Wet or Dry? From your post I would say it is a dry but you used jets as in plural so I am not for sure.
As for dry, I used a 100 shot before maxing out the stock maf.
As for wet, I used Zex kit with a shot inbetween 125 and 150 hp (none of the websites specified what the shot is, the jet size is right between ratings) That put me at about 550 whp and 740 tq on a 11.6 AFR on 111 leaded fuel. I ran that combination for a little over a year (16 bottles of nitrous). But that was as far as the motor could hold. I added long tubes and dual 3" exhaust and gained 30 hp and 40tq on the motor but the stock motor didn't last long enough on the bottle to make a full pass on the dyno.
Old Feb 29, 2008 | 01:27 PM
blazen5.4's Avatar
Wet Kit
Its a wet kit ,i am staying with a 75 shot till i dyno it.
Old Mar 2, 2008 | 04:21 PM
A 6# lower and a potted blower is night and day, plus you'll never run out and have to pay to have anything filled. Let us know how the dyno goes
Old Mar 3, 2008 | 02:41 PM
Ct.TOPGUN's Avatar
Any more and I would want to drop timing a bit. The Maf is not affected by the wet kit at all. My concern is how much HP the stock pumps can support with fuel. I would want to have a wideband to make sure the AF ratio was good with any more nitrous.
