Is there a Oil separator fix-- forever?
I had oil in the intake, (searched forums for what the majority said was pricey but the best= L&S), bought/installed it, still oil in the intake.
Is there a permanent fix short of removing the PVC sys ?
Some folks said this or that, BUT what is the ultimate fix if we are going to keep the PVC system??
If you eliminate the PCV system, it will probably throw a "CE." It needs to be turned off in the computer. I'm pretty sure the XCal2 will "clear" the code, but until it's turned off in the tune, I would expect it to return.
I removed mine, put 4'' stacktubes in the valve covers with K&N filters on each side. So any oil might drain back down. Pluged (all) the hoses. No codes for about 3 years now. I clean them maybe 2 times per season.
