I give up! Need help!
Old Apr 24, 2001 | 01:05 PM
CornerCarver's Avatar
Angry I give up! Need help!
How in the HELL does the tonneau cover that came on my L come OFF?? I can't figure it out for anything! I know, I know...
Old Apr 24, 2001 | 01:08 PM
BlackLight's Avatar
Wink
Take firm hold of the 2 black tabs on the cover, close to or slammed into the tailgate. Pull to the rear of the vehicle and slightly up. You have to stretch the fabric so that it releases the plastic edge from its groove. When re-installing, start at the front and think Tupperware.
Old Apr 24, 2001 | 01:11 PM
Post
Ahhh, thanks. I keep pulling downward on the small plastic tabs "under" the back corners thinking it would slide. Thanks. Now I really feel like and idiot.
Old Apr 24, 2001 | 01:16 PM
BlackLight's Avatar
Cool
No idiots observed. If you broke something and then asked, that would be...
Putting it back on is not easy. I suggest having a helper to maintain the tension and to prevent the plastic lip from slipping out. The part behind the cab slips out sideways. There are also 2 straps that can be used to roll it up behind the cab. Be carefull they can not take a lot of tension. Do not use it as you would a normal tie-down strap.
Old Apr 24, 2001 | 01:29 PM
Rzk's Avatar
Rzk
Thumbs down
Factory tonneau cover is relatively easy to take off, but a pain in the **** to put back on. If you have difficulty releasing the cover by pulling on the tabs, try pushing up on the edge of the tonneau. You will need to pry up on the plastic edge from the groove. Good luck.
Old Apr 24, 2001 | 02:03 PM
LIGHTNINROD's Avatar
Post
i take delivery of an already ordered 01L may 15th. it has the factory soft cover added(by the dealer). i can refuse the soft cover if i don't want it. my question is, do i want it? help! what do you guys think about the soft tonneau covers?
Old Apr 24, 2001 | 02:29 PM
BlackLight's Avatar
Post
For the money, the factory cover is pretty good. It fits just fine, and after 5 autocross meetings, I can re-install it without a helper. I have had it up to 200-and-mumble km/h and it held up well. It gives good weather protection for almost no weight.
Old Apr 24, 2001 | 04:03 PM
NeedFourSpeed's Avatar
Post
I like my EXTANG Black Max aftermarket cover. It is adjustable for winter/summer and attaches w/o drilling any holes. Put a Bedrug under whatever cover you decide. I get alot of compliments on that piece.
Old Apr 24, 2001 | 04:07 PM
Post
I plan on getting mine Rhino Lined sometime soon. I've got a yellow Lab that loves tro ride and sheds to no end. Last thing I need is ANOTHER rug to vacuum!
Old Apr 24, 2001 | 06:52 PM
Gitchi Manitou's Avatar
Post
Just vacuum the dog before you put him in.
Old Apr 25, 2001 | 08:49 AM
Post
thanks blacklight. i will autocross and driver's school too. have you lowered your L? how? if shackles; did handling degrade because of rear end shifting side-to-side?
<font face="Verdana, Arial" size="2">Originally posted by BlackLight:
For the money, the factory cover is pretty good. It fits just fine, and after 5 autocross meetings, I can re-install it without a helper. I have had it up to 200-and-mumble km/h and it held up well. It gives good weather protection for almost no weight.</font>
Old Apr 26, 2001 | 12:07 AM
BlackLight's Avatar
Talking
These are my only mods for autoX:
http://www.zing.com/album/?id=4292916417
It is not neccessary to do anything to the truck, except getting an good alignment. You want to increase negative camber to around 0.75 degrees (top of the tire leans IN). For my Hoosiers, I am running -3 degrees... Run the F1's at at least 44 psi.
In the stock trim you should be competitive in F-Stock class. On the first of the club meetings, (not counting for regional championship points) a multiple US class champion came up from Tacoma WA, and drove the truck to a class win, with me in 3rd place.
Do not be scared of accelerating coming out of corners, but put it in 2nd. You don't want a 3/4 throttle or a WOT downshift in a corner.
[This message has been edited by BlackLight (edited 04-25-2001).]
