A review of the new Accumulator valve body from Factory Tech...
Old Apr 21, 2001 | 05:41 PM
Wyldman's Avatar
Thumbs up A review of the new Accumulator valve body from Factory Tech...
I just installed the accumulator valve body that I got from Factory Tech (Gregg Evans) and I have to say I am impressed!
Shifts are much shorter and much more positive, but not violent (even at WOT). For me this is great, as it doesn't hurt my back. I have ridden in trucks that have the all out Level 10 mods and find that I start aching after a while. (I have 2 collapsed disks at the base of my spine and they trap the nerves that control my legs, causing pretty intense agony under very little duress).
The back end just squats hard on each shift (even going into overdrive!) and the truck leaps ahead, pulling like a tractor all the way. I'm thinking this may even help my times at the track, those long, slow sloppy shifts are a thing of the past!
Dude! It rocks!
Disclaimer: I have no interest in Factory Tech's operations. This information is only my observations of a new mod that I think is worthwhile.
The
<A HREF="http://www.haloclub.com" TARGET=_blank> </A>
wyldman@houston.rr.com
Black 99.5 Lightning Build # 1273, DOB 5-14-99, NLOC #315
Old Apr 21, 2001 | 06:16 PM
jarmstro's Avatar
Post
Chuck,
I'm planning on replacing my Modulator Valve I got from JDM. This too should give me the quicker shifts as you describe. Only problem is I'm not looking forward to dumping 5 or 6 quarts of transmission fluid on my driveway, well maybe not all but messy nevertheless.
Did you replace your pan with one that has a drain plug? I ask our man Steve over at TV for a part number on the 4X4 Ford pan. I beleive the price is around $45 or so.
Regards,
John Armstrong
2000 Red Lightning
#444 of 4966
Born 2/22/2000
Went home 3/6/2000
Old Apr 21, 2001 | 07:01 PM
Lightning Boy's Avatar
Post
jarmstro, yes we are useing the Ford 4x4 trnny pan w. drain plug. It took us about 45minutes to an hour to install and put all back to gether. With the drain plug, there was very little mess in the garage.
SVTPerformance.com
BOARD MODERATOR:
-Nitrous/Forced Induction
-Dynos, Time slips, and best ETs
Houston Area Lightning Owners
Old Apr 21, 2001 | 08:08 PM
JoeLightning's Avatar
Post
Just a thought about preventing the "garage mess" that comes with dropping the tranny pan. For 5-10 bucks at your favorite building supply store (Home Depot or Lowes) you can pick up an incredibly large low profile retangular tub for mixing cement or motor. These work great under a tranny pan to catch the "falls".
Old Apr 22, 2001 | 11:42 AM
ShadowBolt's Avatar
Post
Glad to hear it worked out well Chuck. I finally got under mine yesterday to get the numbers off the trans. so I can order one. I'll be ordering one next week.
Jerry
Old Apr 23, 2001 | 10:25 AM
Lightfootning's Avatar
Post
If you are going to put on a new pan with a drainplug, just pop a whole in the bottom of the old trans pan and let the fluid drain out VS unbolting the pan and having the fluid splash all over. No mess that way. Same thing works good for the engine oil filter.
My new pan cost $40.73 The stupid filter was more !!!! $51.76
One thing I don't like about the Ford 4X4 trans pan is that the drain plug is on the bottom instead of on the side. On a lowered L, it looks like it could be an invitation for disaster. I can visualize a nasty speed bump ripping that bolt right out. I have not installed mine yet, still contemplating relocating the drainplug to the side of the pan.
Old Apr 23, 2001 | 10:30 AM
Post
Part numbers
F81Z-7A194-BA PAN ASY-TRAN 40.73
F6TZ-7A098-BB FILTER & SEAL 51.75
F6TZ-7A191-A GASKET-TRANS O 25.56
Old Apr 23, 2001 | 10:55 AM
John893's Avatar
Post
You don't need to do a new gasket. It even says on the pan that the gasket is re-useable. I just did mine and the stock gasket worked fine the second time around.
93 Teal Cobra #4656
2000 Silver Lightning #4524
Old Apr 23, 2001 | 01:28 PM
John893's Avatar
Post
This is from the instructions that Factory Tech sent to me:
"Torque all the nuts and bolts, working from the center out, the torque is 80-100 in/lbs"
That is for the accumulator.
93 Teal Cobra #4656
Old Apr 24, 2001 | 12:03 AM
FlaSVT's Avatar
Banned
Post
Wyldman - You wouldn't happen to have the torque specs for the bolts on the valvebody would you?
Rick
SVT Performance
Moderator 2nd Gen Lightnings
White 00 #2236 of 4966
My Mods & Web Page
<A HREF="http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/p0903ca5788ed2e743923d60b1a060fed/feb8b2de.jpg" TARGET=_blank> </A>
Old Apr 24, 2001 | 12:51 AM
2000Black's Avatar
Post
Wyldman,
Do you run at the track? Can you get us some before/after timeslips? That would rock!
2000 Black Lightning
#1326 of 4966
Born on 03/20/2000
PSP Chip
PSP Filter
Best time: 13.248 @ 104.4 mph
